#1 Posted : Thursday, 31 May 2007 10:38:46 PM(UTC)
Can anyone ell me if the crown and pinion gears are interchangable from commodore salisbury diffs to the HQ V8 diff gears and if so are the hemi's as well.
#2 Posted : Friday, 1 June 2007 1:54:40 AM(UTC)
Hi Reece.
There are 2 different Holden 'Salisbury' diffs.
The so-called 'Large' Salisbury was fitted to all HQ to WB V8s, All One-Tonners (HQ to WB), LX Torana A9X & 5.0-litre V8 Commodores from VB to VK. It was also available as the heavy duty opt
#3 Posted : Friday, 1 June 2007 2:55:03 AM(UTC)
Terry
I think 3.08 large salisbury are the same hemisphere as 3.36 to 4.44.
2.6 and 2.78 are the same as each other.
I think it's the banjos that are common centres between 2.78 and 3.08.
Although rare, the VB Rally car had the large salisbury as
#4 Posted : Friday, 1 June 2007 3:21:05 AM(UTC)
Hi Byron.
That's why I said "from memory". I couldn't remember where the cut-off was.
The problem with swapping banjo diff gears, is that the 2.78 & 3.08 won't fit into the cast housing used 3.36 & down. That's why they had the casing with the 2 lon
#5 Posted : Friday, 1 June 2007 4:09:45 AM(UTC)
I do the same often.
