mmazz30 Offline
#1 Posted : Friday, 1 June 2007 8:27:47 AM(UTC)
mmazz30
Hi all I know its been done to death,and i have done and read the searches.
I have the complete top end off an 5.0 efi VN already and engine loom.
Apart from the engine loom,what other wiring is required under the bonnet and under the dash?
The vehicle is an HJ with GTS dash.
Has anyone here done a wiring diagram to splice VN engine loom into the original engine loom/plug into firewall.
Thanx for any help.
Cheers.....Mario
#2 Posted : Friday, 1 June 2007 7:27:18 PM(UTC)
Mario
I've planned all of this, but haven't done it yet (I cheated and stuck a Redline Hi-winder manifold, Holley and HEI dizzy on for now). But these are the things I have planned and figured out so far as far as wiring is concerned:
1. You need a
Holdenute Offline
#3 Posted : Friday, 1 June 2007 7:44:04 PM(UTC)
Holdenute
Byron's got it all covered. I've used the VN fuse and relay set-up and found it pretty easy to wire up. One thing to note is the VN uses negative switches for the headlights while the HQ-WB use positive. Once I'd figured it out didn't take much to swap a
Edited by user Friday, 1 June 2007 7:58:25 PM(UTC)  | Reason: Not specified
Never late in a V8
Holdenute Offline
#4 Posted : Friday, 1 June 2007 8:00:19 PM(UTC)
Holdenute
http://gallery.oldholden...Fuse_box_Wiring.jpg.html
http://gallery.oldholden...bum137/Fuse_box.jpg.html
Never late in a V8
Edited by user Friday, 1 June 2007 8:01:28 PM(UTC)  | Reason: Not specified
Never late in a V8
#5 Posted : Friday, 1 June 2007 9:30:26 PM(UTC)
Excellent. The beauty of using the Commodore fuse and relay box is that you can use the spare relays for things like headlights, electric fans etc. If you can afford $500 for a bit of hardware and can solder a socket into your Memcal you can also play aro
ED57FE Offline
#6 Posted : Friday, 1 June 2007 10:07:16 PM(UTC)
ED57FE
ive done the conversion and it tedious but straightforward.
I run thermos by hooking them up as "AC fans", and sending an AC on signal to the ECU. Since the ECU was remapped anyway I had the cut in temp adjusted accordingly.
Fans automatically come o
mmazz30 Offline
#7 Posted : Saturday, 2 June 2007 6:42:28 AM(UTC)
mmazz30
Thanks everyone it gives me an idea on the extra wiring required.
I am actually going a different route in that i will adapt the VN V8 wiring and injection hardware onto the standard red 308 engine ie tig welding injector bosses onto the standard pre pol
#8 Posted : Saturday, 2 June 2007 7:50:42 PM(UTC)
Mario
Edelbrock etc sell maifolds for SB Chevs with injector basses so someone may do one for a red/blue 308?
ED57FE Offline
#9 Posted : Monday, 4 June 2007 5:56:38 PM(UTC)
ED57FE
Mario,
I run injection on a dual plane manifold and it runs great!
keep us updated on your conversion, it sounds good.
Ed
Edited by user Monday, 4 June 2007 5:57:16 PM(UTC)  | Reason: Not specified
mmazz30 Offline
#10 Posted : Tuesday, 5 June 2007 7:45:45 PM(UTC)
mmazz30
I will keep you posted as i'm now on arvo shift and can slowly get things going in the morn-midday and chase up bits and pieces to suit.
So far have sussed out that 2 of the 3 injectors in the VP onwards V6 alloy fuel rails line up at the right angle and
#11 Posted : Tuesday, 5 June 2007 10:12:17 PM(UTC)
You could always weld bosses on. One way to save you some time - I have a Mcgee/air sensors EFI setup at home. It simply uses T-pieces and high pressure hose for the fuel rails. Something copied off that might be easier?
_______________________________
mmazz30 Offline
#12 Posted : Thursday, 7 June 2007 8:19:59 AM(UTC)
mmazz30
Hi Byron,
I will be welding in the bosses on the manifold side and use the vp rail sections on top.
Each end of the rails has the same fuel pipe insert so i can use the o-ring pipes and join it.
Thought about the way you said and it may go that way,but
