mzap01 Offline
#1 Posted : Monday, 4 June 2007 4:22:42 AM(UTC)
mzap01
ky last post was i put high octane in blue 253 what i meant was i put high ethonol in.always run high octane but with high ethonol motor is running about 10 degrees cooler (bet75-80)otherwise fine.is this a safe temp and is ethenol safe in a blue 253(mildly worked)
mzap01
mzap01
hz dude Offline
#2 Posted : Thursday, 7 June 2007 5:53:38 AM(UTC)
hz dude
ethonol as a rule for older engines is ok. when u get a newer car thats the sticking point comes with voided warranty. but it is harder too kill a older engine, well thats what I think any way so I dont think there would be a problem but I could be wrong.
peter_flane Offline
#3 Posted : Thursday, 7 June 2007 7:11:52 AM(UTC)
peter_flane
Ethanol is not necessarily going to work well on a carby engine. You would need to rejet it to work correctly with ethanol fuel. It will run lean if the jets are set to run most efficiently with regular petrol. Injected vehicles with O2 sensors will autom
#4 Posted : Thursday, 7 June 2007 8:48:52 AM(UTC)
Are we talking Ethanol or methanol here.In 03 the Goverment agreed that 10% ethonal was ok in our fuel in some states it became law that it had to say if the fuel on sale had Ethanol in it.Ethanol has a higher octane rating than petrol but is generally re
