#1 Posted : Friday, 3 September 2004 5:23:14 PM(UTC)
Hello,
I have a VP Commodore that constantly display the engine warning light. I have taken it to a Holden dealer and so far they have replaced the oxygen sensor which did not fix the problem. They then replaced the computer which still did not fix the problem.
They still have the car and cant seem to find the cause of the problem.
Do any of you guys know what else we could try, as I have run out of ideas and patients.
Thanks in advance.
#2 Posted : Friday, 3 September 2004 6:43:35 PM(UTC)
is it on gas?? My VN is and the engine light stays on the whole time the engine is running. One mechanc told me that it was because it had a dodgy gas conversion. I thought we was a wanker that didnt want to look for the problem. After a while I forgo
#3 Posted : Friday, 3 September 2004 6:48:11 PM(UTC)
Thanks for the reply. No it is not on gas. Nobody at Holden can seem to find what the problem is.
#4 Posted : Friday, 3 September 2004 8:30:42 PM(UTC)
My VR wagon was doing the same thing, but the abs light and airbag fail light was also coming up intermitantly. It ended up being the main charge wire at the back of the alternator had perrished to a point where it was not always working properly, ie, eve
#5 Posted : Saturday, 4 September 2004 9:07:15 AM(UTC)
i cant remember the fault code lists for vps, but u can easily look them up online, and by bridging a terminal under your dash, it puts your computer into self test mode...it should give you the code for what is setting the light off. other than that, che
#6 Posted : Saturday, 15 January 2005 2:17:36 PM(UTC)
Looking for answers to 2001 Barina with same problem. Emission Control LIght on and car loses power. Has been ongoing for 14 months and has been back to dealer 8 times (sometimes for up to 4 days). Comes out OK and light appears on next day. All they
