#1 Posted : Saturday, 9 June 2007 5:33:59 AM(UTC)
wanting to know if the 5speeds out of holdens around the same time as the vs v6 bolt straight up,,,eg vn.ect as i have a vs with a bad auto in it. or what would be the best box to put in it as every day driver,,will i have to change the diff ratio
#2 Posted : Saturday, 9 June 2007 10:40:40 PM(UTC)
im not 100% sure. but after you get the peddle box,cut the hole and change the some of your console. change the computer. it might be easier to sell it and buy a VS with a 5sp in it. VT are a really good price now so you could up date.
#3 Posted : Sunday, 10 June 2007 8:39:40 AM(UTC)
HEY MATE JUST PUT A AUTO BACK IT THE SAME SORT AS WHAT CAME OUT. THERS A STICKER ON THE AUTO ITS LIKE(4HDD) JUST GET 1 OF THEM AS GOING 5 SPEED WILL COST HEEPS EG 2000 AND THEN U HAVE TO FIT IT. ITS A PAIN IN THE BUM AND YOUR CAR WILL NOT BE WORTH ANY MOR
jabba Offline
#4 Posted : Monday, 11 June 2007 3:09:50 PM(UTC)
jabba
There is a wrecker here in Welly (NZ) who regularly sells and performs these conversions with kits on trademe. Might be worth looking at his listings, and /or giving him a call to see what is reqired
Keep t
Mr Void Offline
#5 Posted : Monday, 11 June 2007 8:09:04 PM(UTC)
Mr Void
the diff ratio is the same. VS's have a T5 (well mine does from factory). You would need a manual flywheel from memory they have extra dowels in the for whatever reason.
The whole conversion will cost a fair bit (as above.. you'd probably be better off
___________________
Mr Void Offline
#6 Posted : Monday, 11 June 2007 8:09:04 PM(UTC)
Mr Void
the diff ratio is the same. VSs have a T5 (well mine does from factory). You would need a manual flywheel from memory they have extra dowels in the for whatever reason.
The whole conversion will cost a fair bit (as above.. youd probably be better off g
___________________
#7 Posted : Wednesday, 13 June 2007 8:37:28 AM(UTC)
Hello if u decide to stick with the auto make sure u replace it with a transmission with code number 6HDD or 7HDD. If u need a rebuilt performance trans with a shift kit and performance mods, let me know I build them and freight them all over Australia.
#8 Posted : Wednesday, 13 June 2007 6:44:48 PM(UTC)
#9 Posted : Wednesday, 13 June 2007 11:37:13 PM(UTC)
Big mistake Terry ????????????????? All VS autos are 6HDD or 7HDD in V6 the only other one is a 8HDD in VS series 3 ute. 4HDD is VR 1 5HDD is only VR 2. From what i read we are talking about a VS V6.
#10 Posted : Thursday, 14 June 2007 1:19:37 AM(UTC)
Hi luketroy.
My comment was based on the 4HDD number that the 3rd post (hqmonaro) mentioned.
What you say is basically true, except that the 4, 5, 6 etc changeover doesn't happen exactly on the model cutoff. You do get 4HDD autos in early series 2 V
#11 Posted : Thursday, 14 June 2007 1:19:37 AM(UTC)
Hi luketroy.
What you say is basically true, except that the 4, 5, 6 etc changeover doesnt happen exactly on the model cutoff. You do get 4HDD autos in early series 2 VR
#12 Posted : Tuesday, 23 October 2007 7:13:21 AM(UTC)
hi what would happen if put a 5hdd in a car that have a 4hdd place. i think i may have done this but the auto doesnt even move. thanks damien
#13 Posted : Tuesday, 23 October 2007 7:13:21 AM(UTC)
hi what would happen if put a 5hdd in a car that have a 4hdd place. i think i may have done this but the auto doesn't even move. thanks damien
#14 Posted : Tuesday, 23 October 2007 7:17:18 AM(UTC)
just to edit my last post. due to the box doesnt move do i need to change the woring loom. i have one sitting there that came form the trans. would this solve the problem. is the wiring differnt. thanks damien
#15 Posted : Tuesday, 23 October 2007 7:17:18 AM(UTC)
just to edit my last post. due to the box doesn't move do i need to change the woring loom. i have one sitting there that came form the trans. would this solve the problem. is the wiring differnt. thanks damien
#16 Posted : Saturday, 22 March 2008 9:36:10 AM(UTC)
hey all, ive just compleated auto manual conversion in my vs v6. i purchased a wrecked vs with 5spd and pretty fresh motor off a mate so thort id do the convo all went well but didnt change wiring harness
#17 Posted : Saturday, 22 March 2008 9:40:56 AM(UTC)
but i did change computers, any way i turn the key fuel pump works and engin cranks but wont start i notice wile im turning it over the imoboliser lite keeps flashing? how do i get it 2 start! HELP!!!
