peterwmh Offline
#1 Posted : Monday, 2 July 2007 2:15:48 AM(UTC)
peterwmh
Hi all,
After a thorough inspection of my HZ statesman it seems the welch plugs at the back of the motor are leaking too (green fluid coming out of the bellhousing dust cover gave me that clue!). OK I'm assuming this means engine and tranny out to do properly, however has anyone successfully done these ones by just removing the tranny (T400)? The engine was rebuilt 35000kms ago but it appears they didn't change the welch plugs at this time (just crazy). Anyway any suggestions would be appreciated.
Ta
Peter
#2 Posted : Monday, 2 July 2007 3:44:48 AM(UTC)
Hi peter.
You can just remove the TH400, but you will only gain access to the 4 welsh plugs on the back of the block.
I would pull the whole engine & 'box & replace all the plugs. Otherwise you will be in the same boat next time one of the remaining
peterwmh Offline
#3 Posted : Monday, 2 July 2007 5:20:12 AM(UTC)
peterwmh
Thanks Doc, yes I'm fast coming to that conclusion, looks like motor and tranny out, bummer!!
Peter
#4 Posted : Monday, 2 July 2007 11:19:02 AM(UTC)
you can pull the box but it's a pain in the arse and you cannot get at the plugs very easily in the long run better to pull the motor and box. don't forget to drain the gearbox oil so you don't drip it everywhere out of the rear extension
#5 Posted : Tuesday, 3 July 2007 1:04:08 AM(UTC)
on the welch plugs i have a 253 block whith no welch in it and the two outer holes at the back are shallower because of extra around the back of the hole is this normal ? cheers
#6 Posted : Tuesday, 3 July 2007 5:55:45 AM(UTC)
you will find these take the shallow dome plugs not the deep cup types.
peterwmh Offline
#7 Posted : Tuesday, 3 July 2007 7:39:27 AM(UTC)
peterwmh
Thanks guys, much appreciated.
Peter
