farrblake Offline
#1 Posted : Tuesday, 12 June 2007 12:04:27 AM(UTC)
farrblake
Hi Guys. Am fairly new to this site and don't know if this subject has been covered before, so I apologize in advance if it has.. I am just about to pull a 350 out of my HZ Sandman and replace it with a 308. I have a T400 in at the moment, but the 308 comes with a T350. Now my dilemma Should I keep the 400 or change to the 350 when the 308 goes in, and will I have make any mods eg. tailshaft or will it just slip straight in to replace the 400.
Any and all thoughts would be greatly appreciated
Thanks Shane
Grouse F###ing site by the way
#2 Posted : Tuesday, 12 June 2007 12:32:06 AM(UTC)
the 400 will bolt straight up to the turbo pattern block, 400`s are a very strong trans, tailshaft should be the same.
#3 Posted : Tuesday, 12 June 2007 3:54:50 AM(UTC)
TH350 uses different yoke/tailshaft, kickdown (mechanical instead of TH400's electrical), crossmember plus more. Unless it's a very late HZ it will be a TH400 factory so i'd leave it (assuming it was originally a 308 auto).
____________________________
farrblake Offline
#4 Posted : Tuesday, 12 June 2007 4:34:37 AM(UTC)
farrblake
Thanks Guys for the input Will leave as TH 400 I think, as a mate built box and I know its a goodie, who knows what the 350's like.
Byron, originally was a 308 4 speed and will put it back that way one day but have to leave it auto for the time being
#5 Posted : Tuesday, 12 June 2007 6:40:51 AM(UTC)
Just make sure that it has the smaller TH350 size torque converter as that is what you need for a 308. Just check it against the 308's flex plate that the bolts line up.
If we all had the same (g
farrblake Offline
#6 Posted : Tuesday, 12 June 2007 6:50:32 AM(UTC)
farrblake
Would I be able to swap the torque converters around by putting the one out of the TH350 behind the the 308 and TH400 and then putting the one that is now in the TH400 into the TH350 to put behind the chev or is it to big to fit in, if that makes sense
#7 Posted : Tuesday, 12 June 2007 6:58:54 AM(UTC)
AFAIK the TH400 one won't fit in the TH350. The one in the TH400 may be the right one for the 308 as most TH400's that came into Australia were behind a 308.
If we all had the same (good) taste,
farrblake Offline
#8 Posted : Tuesday, 12 June 2007 7:05:15 AM(UTC)
farrblake
Cool, Will just have to sus it out when I change engines over Thanks for all your help mate. Shane
JBM Offline
#9 Posted : Tuesday, 12 June 2007 7:21:32 AM(UTC)
JBM
What are you going to do with the 350 and what condition is it in?
James
#10 Posted : Tuesday, 12 June 2007 7:23:29 AM(UTC)
If you need to know more check with an auto specialist. My experience with autos is limited to using the strongest one possible (TH400) and looking after them (plus what interchanges with what).
farrblake Offline
#11 Posted : Tuesday, 12 June 2007 7:43:12 AM(UTC)
farrblake
Hi James The chev is actually a 327 stroked to 350 and will be selling it with TH350, extractors and radiator to suit HQ-WB The engine is 30 thou, has mild cam (TQ30 for memory) Big valve heads 202 inlet but can't remember exhaust, and was built for st
