#1 Posted : Saturday, 16 June 2007 8:43:08 PM(UTC)
I currently have a hq trimatic, fitted to my hr ute, with T/bar on the floor.
I am altering back to column shift(auto).
Any suggestions on specific linkage, that will fit from gearbox trunion to steering box???.
#2 Posted : Sunday, 17 June 2007 7:53:03 AM(UTC)
As the HR used a powerglide I do not think you can use it for a trimatic.
The reason for this is the floor shift for a powerglide pushes forward when the lever moves forward and a trimatic the lever pushes back when the lever is pushed forward. You cou
#3 Posted : Sunday, 17 June 2007 8:22:39 PM(UTC)
Hi Guys.
The HG Tri-Matic T-bar operates the same as a HK/HT Powerglide T-bar. All they did was to reverse the lever on the side of the Tri-Matic box to point down so it pushes forward into park. The T-Bar mechanism (on the floor) is virtually the same
