basketcasebear Offline
#1 Posted : Monday, 25 June 2007 5:02:50 AM(UTC)
basketcasebear
hey all, can i run a wire from battery to coil, via switch, with fuse, and will this give me ignition?
and are there any probs doing this?
thanks all ready
ptpro
DOH!!!
81837 Offline
#2 Posted : Monday, 25 June 2007 6:33:40 AM(UTC)
81837
That will do it FB, although some systems run a resistor to drop coil voltage in series with the coil.
#3 Posted : Monday, 25 June 2007 8:24:04 AM(UTC)
basketcasebear
eerrh? thanks 81837,
have not understood though, what is "FB",? and what is in series mean? I just wanted to go straight from battery to the coil and electronic igniton, , with a switch and fuse in the middle?
the reason is, i have lost ignition,
DOH!!!
#4 Posted : Monday, 25 June 2007 8:06:42 PM(UTC)
What car?
You note an electronic dizzy?
If it is the blue/black motor HEI dizzy, then you can run a wire direct from the battery + post, to the fat pink wire on the + side of the coil, and it will run fine to get you there.
_____
Mr Void Offline
#5 Posted : Tuesday, 26 June 2007 4:38:52 AM(UTC)
Mr Void
___________________
#6 Posted : Tuesday, 26 June 2007 6:26:24 AM(UTC)
basketcasebear
hey thanks mr void,
thats what my brain was when i read the reply, void!!!!
but hey it worked, only hope it wont cause any long term probs? funny thing is, if i didnt know any betterer,, i would say motor is actually running betterer!!! i had t
DOH!!!
