#1 Posted : Sunday, 5 September 2004 4:20:57 PM(UTC)
Hi,
Just wondering if anyone knows what could cause an airbox to keep getting blown up? Its in my VN SS thats on LPG, the strange thing is there is no problem unless its cold, sometimes when you go to start it it back fires and blows the box appart. I've done the timing and changed leads, plugs, filters etc. I'm thinking of doning the timing chain as its getting on a bit now. Also when i switch to petrol the thing idles at about 1500. If anyone has any ideas they would be greatly appreciated.
Thanx in advance.
#2 Posted : Sunday, 5 September 2004 6:46:08 PM(UTC)
Also same problem is a concern to 1993-4 Land Rover owners on gas, blows the end out of air cleaner barrel with back fire.
#3 Posted : Sunday, 5 September 2004 7:50:15 PM(UTC)
it is the leads. put really good ones on there. When they are on gas they are bastards for doing this.
Or cut a huge hole in the airbox and have a hinged flap covering the hole, when the engine is sucking the flap stays closed, but when she back f
#4 Posted : Monday, 6 September 2004 7:35:39 AM(UTC)
I found this happened when a bit low on gas. I was told by the rAC to cut a flap like suggested above.
#5 Posted : Monday, 6 September 2004 11:01:46 AM(UTC)
Thanx heaps guys, i'll give it a go, sick of buying new boxes all the time.
#6 Posted : Monday, 6 September 2004 9:15:36 PM(UTC)
My Falcon on LPG did this but I was lucky that it only blew the lid off & bent all the holding clips. I put a new set of leads on it & the problem went away. You can buy a backfire arrestor from an lpg fitter which is I believe just like the flap
#7 Posted : Thursday, 30 December 2004 5:59:03 AM(UTC)
its a problem with your lpg go to an lpg mechanic and get it checked out they will be able to fix it up
Guest (5)
This page was generated in 0.145 seconds.
