#1 Posted : Wednesday, 27 June 2007 1:14:43 AM(UTC)
Howdy,
May have asked this question before - can't remember....
Are all 308 cranks the same? For example will the crank from my Aussie pattern QT 308 go into a turbo pattern block no prob's? What should I pay for a turbo block at 40 thou or under....?
The Beige Hornet.
#2 Posted : Wednesday, 27 June 2007 1:24:18 AM(UTC)
Also, can you use a 308 crank in a 253...?
The Beige Hornet.
#3 Posted : Wednesday, 27 June 2007 1:33:50 AM(UTC)
The Beige Hornet.
#4 Posted : Wednesday, 27 June 2007 1:38:16 AM(UTC)
I just got shoty motor at 40thou for $750. Block only should be less - but mine was rebuilt and date coded, so worth it!!! Thanks to Mick from Hunter Valley.
#5 Posted : Wednesday, 27 June 2007 4:03:31 AM(UTC)
Thanks for that!
The Beige Hornet.
#6 Posted : Wednesday, 27 June 2007 4:38:49 AM(UTC)
There are 3 different Holden 5 litre cranks:
308 neoprene rear main (roughly HT-HQ).
308 rope rear main (roughly mid HJ-mid VK).
304 rope rear main (mid VK - 2000 VSIII).
They are all interchangeable as long as you have the right crank for the rig
