xcrpakute Offline
#1 Posted : Sunday, 8 July 2007 7:28:47 AM(UTC)
xcrpakute
Swapping from electronic dizzy (std bosch/ford elec dizzy & ecm)
to points on an XC. Is it just a matter of hooking the coil up, setting points and the timing .
Do I have to leave the module plugged in or can I remove the module from the car.
Tony
#2 Posted : Friday, 13 July 2007 9:52:48 AM(UTC)
why bother?
xcrpakute Offline
#3 Posted : Saturday, 14 July 2007 9:15:43 AM(UTC)
xcrpakute
The original motor in my ute is cactus, so out it comes and the spare motor for my coupe is going in, The old motor and dizzy are going to be rebuilt and transplanted in to the coupe hopefully in time for the Hardtop anniversary in Echuca in September (ca
#4 Posted : Monday, 16 July 2007 12:06:57 AM(UTC)
fair enough... the main thing that must be done is that assuming the electronic dizzy was wired up correctly with 12 volts to the coil positive , the voltage will then have to be dropped back down to 9 volts to suit the points dizzy and coil .if this is n
xcrpakute Offline
#5 Posted : Wednesday, 1 August 2007 3:10:42 AM(UTC)
xcrpakute
Thanks christoss works a treat
P.S
sorry for the late reply been on hols
Cheers Tony
383XB Coupe Offline
#6 Posted : Thursday, 2 August 2007 10:21:38 PM(UTC)
383XB Coupe
Hmmm this makes me think, lets say you have a motor with an electronic dizzy and something goes wrong with it so a points dizzy is put on, lets say this car is straight gas, and lets say after a while the motor starts running like pure crap, and it is sai
#7 Posted : Monday, 6 August 2007 12:33:47 AM(UTC)
burnt out points could definately cause poor running, especially running on lpg when your ignition system must be kept in a1 condition.But having said that pitted valves would generally cause a lot of backfires, best just to check points, voltage at coil
