iitsmint Offline
#1 Posted : Monday, 2 July 2007 7:48:43 AM(UTC)
iitsmint
Hello all, in the process of putting turbo 700 in my hz ute, couple of minor problems, the mounting holes for the rear mount are forward of the gerarbox cross member. so what do i use,
turbo 350 cross member?????
what mount do I use trimatiuc standard mount iss this the corect hight or is there something else, the turbo 400 mount boltholes are not the same, but a trimatic are?????????
#2 Posted : Tuesday, 3 July 2007 2:02:19 AM(UTC)
just read castlemaine rod shop make a cross member just for that purpose cheers
#3 Posted: : Tuesday, 3 July 2007 2:32:01 AM(UTC)
Also www.v6conversions.com.au sell a cross member to do this
#4 Posted : Tuesday, 3 July 2007 4:06:03 AM(UTC)
Hi iitsmint.
I have exactly this combination in my HZ One Tonner. The TH700 is not only further forward than the TH400 & Tri-Matic, but it's also much lower down. I used a TH350 crossmember & mounted it around 40mm further back to line up with the moun
musksell Offline
#5 Posted : Tuesday, 3 July 2007 8:55:53 AM(UTC)
musksell
Dr terry
what motor/diff ratio are you running with T700
Did you get T700 rebuilt or did you just buy one from wreckers....?
#6 Posted : Tuesday, 3 July 2007 5:55:41 PM(UTC)
Hi Muskell.
I used a standard 5.0 EFI/TH700R4 out of an early VP. I left the motor stock (I wanted good torque & economy), just swapped the mounts, sump & oil pick-up & just put a kit through the auto. It's always cheaper & easier to overhaul the auto
#7 Posted : Wednesday, 4 July 2007 1:12:08 AM(UTC)
I READ ON THIS SIGHT JUST RECENTLY THAT THE TURBO 700 WAS AS WEAK AS PISS JUST WONDERING OR IS THAT AFTER A CONTINUAL FLOGING ? CHEERS
musksell Offline
#8 Posted : Wednesday, 4 July 2007 3:10:34 AM(UTC)
musksell
Alot depends on opinion I guess...I've asked a couple of automatic specialists and they have said its pretty ordinary. Yarra valley auto's Melb (Tony Spooner ) is one. Probably alot depends on how it is thrashed.
On the above note, I have a Hadfield cr
HK1837 Online
#9 Posted : Wednesday, 4 July 2007 4:24:16 AM(UTC)
TH700R4 does get a bad rap, but if treated properly they are OK. I think the biggest problem with early ones is towing in 4th. They are nowhere near as tough as a TH400, but they can be built to be very strong. The later versions of the box are quite good
Edited by user Wednesday, 4 July 2007 4:18:37 PM(UTC)  | Reason: Not specified
#10 Posted : Wednesday, 4 July 2007 6:03:53 AM(UTC)
Hi all, I got the t350 cross member aftermarket on and the standard t700 mount, all bolts in fine ta. jas
