#1 Posted : Tuesday, 3 July 2007 8:33:09 AM(UTC)
Looking at buying this car and would appreciate some help working out what all these codes mean.
vin tag 8C69RG J546077X
main tag model LX8VC69
body 546077m
trim 1900-67y
paint 567-15946
eng l32
trans M40
axle GU7
Other tag build 10-76
BLX023328m
Stamped on chassis BLX023328M
and if im not pushing my luck the engine no is QT911763. Could someone tell me what model car it’s from? the owner told me it’s not the original motor.
Thanks in advance
Bruce
JBM Offline
#2 Posted : Tuesday, 3 July 2007 8:58:38 AM(UTC)
JBM
8C is an SL model, 69 is a sedan, R is high comp 253, G is built between Sep 76 and Aug 77, J546077 is a Melbourne PSN and X is for an LX.
LX8VC69 is an LX SL sedan.
1900 is exterior colour code for Persian Sand Metallic, 67Y Tan Vinyl.
567-15946
Edited by user Tuesday, 3 July 2007 8:59:12 AM(UTC)  | Reason: Not specified
#3 Posted : Tuesday, 31 July 2007 10:56:45 PM(UTC)
I got this car off my uncle i know its a torana LX SL sedan 6/77 i have this number but dont know what it stands for i came across your great site while looking for torana parts the number is
model lx8vc69.
8c69dg j581997 could you identify this and
#4 Posted : Tuesday, 31 July 2007 11:05:24 PM(UTC)
JBM Offline
#5 Posted : Wednesday, 1 August 2007 12:27:40 AM(UTC)
JBM
Its an LX SL Sedan Dandenong built with a 173 6 cylinder.
The trans code on the passenger side plate will tell you what the gearbox or auto is, M20 or Trimatic.
The axle code is for the diff ratio.
James
Edited by user Wednesday, 1 August 2007 12:29:01 AM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 1 August 2007 3:34:55 AM(UTC)
Quarter Horse.
You have listed G as between sept 76 and Aug 77.
why is this so?
i.e why not G = 76 only?
and H for 77 only?
Great web site.
adam
JBM Offline
#7 Posted : Wednesday, 1 August 2007 3:40:48 AM(UTC)
JBM
The year codes run from 1 Sep to 31 Aug each year, so for LHs etc
D= Sep 73 to Aug 74
E= Sep 74 to Aug 75
F= Sep 75 to Aug 76
G= Sep 76 to Aug 77
etc
James
You only have to be in fr
#8 Posted : Wednesday, 29 August 2007 3:25:13 AM(UTC)
how can i tell if a slr5ooo is the real deal by the compliance plate what is the code 4 them
#9 Posted : Wednesday, 29 August 2007 3:36:06 AM(UTC)
Unless its been altered, an SLR5000 will be 8D69T on the VIN plate and 8VD69 on the BODY plate with L31 as the ENG designation.
#10 Posted : Wednesday, 29 August 2007 3:36:06 AM(UTC)
Unless it's been altered, an SLR5000 will be 8D69T on the VIN plate and 8VD69 on the BODY plate with L31 as the ENG designation.
JBM Offline
#11 Posted : Wednesday, 29 August 2007 5:06:23 AM(UTC)
JBM
An L34 is also an SLR5000 with a 8D69Z... VIN with the same Model No and an L34 Engine Code on the Body Plate.
James
#12 Posted : Wednesday, 29 August 2007 5:58:32 AM(UTC)
As is an A9X, but harder to pick from codes alone.
#13 Posted : Friday, 7 September 2007 12:30:33 AM(UTC)
if you are venturing into the wild wild world of toranas, check out gmhtorana.com
All the info you need is there.
#14 Posted : Friday, 7 September 2007 12:41:18 AM(UTC)
Hi Guys.
It's gmh-torana DOT com
#15 Posted : Friday, 7 September 2007 12:41:18 AM(UTC)
Hi Guys.
Its gmh-torana DOT com
#16 Posted : Thursday, 17 April 2008 6:52:34 PM(UTC)
Please help
im looking at buying a sl/r5000 and on the body plate the engine is L31 (308)
M20 (floorshift four speed) and rraxle is G70 (is that an original sl/r5000)
im wondering why it has a police number and can i check it(if so how).
the engine n
JBM Offline
#17 Posted : Thursday, 17 April 2008 7:00:36 PM(UTC)
JBM
The gearbox code should be M21 for a 308. The VIN is on the long skinny plate on the centre of the firewall. Post this number to cross check the trim level and motor code. Diff code could be G70 (2.78:1) or GU4 (3.08:1). The chassis number is behind the d
Edited by user Thursday, 17 April 2008 11:05:12 PM(UTC)  | Reason: Not specified
#18 Posted : Thursday, 17 April 2008 7:03:40 PM(UTC)
you need the model codes , driveline codes alone cannot correctly identify a car.
all 5 litre 4spd should be m21, G70 is 2:60 diff ratio which would give good top end speed.It would need a good amount of power to get off the line though.
#19 Posted : Thursday, 17 April 2008 10:19:47 PM(UTC)
Hmmm. G70 is 2.60:1, which was only available on LX SLR5000 A9X. M20 - are you sure? Email me the VIN number (long skinny plate) and i'll check for you to see if it is an A9X. If the plates aren't bodgied up something is wrong. AFAIK A9X's only had M21 or
#20 Posted : Thursday, 17 April 2008 10:19:47 PM(UTC)
Hmmm. G70 is 2.60:1, which was only available on LX SLR5000 A9X. M20 - are you sure? Email me the VIN number (long skinny plate) and ill check for you to see if it is an A9X. If the plates arent bodgied up something is wrong. AFAIK A9Xs only had M21 or JC
Guest (10)
This page was generated in 0.083 seconds.
