2 Pages<12
#21 Posted : Monday, 16 July 2007 1:45:14 AM(UTC)
I'm not trying to argue with you Byron, what i have read so far on this forum from you is very interesting, heck you know more than i do! but this HP308 block is a lot heavier, thicker cast webs than a F5000/L34 block, i should know cause seen both of the
#22 Posted : Monday, 16 July 2007 3:40:42 AM(UTC)
It may be an aftermarket block, or some sort of special built by Repco? All I can tell you is that the original 308's had HP on the side, and they are identical to the early 308 blocks. I've seen plenty of them. I conversed with Ben Stewart about this a w
2 Pages<12
