#1 Posted : Monday, 6 September 2004 8:00:33 PM(UTC)
Having a problem with the gear selector on my HZ column shift T400. After fitting a new blinker switch on the weekend, it seems something has gone 'boing' and the lever won't lift past the stops in Park etc. The springyness in the lever forward and back is not there anymore. It was getting stiff prior to the fixit job I did too. Any ideas on how to fix this, is there a spring or something that may have fallen out/dislodged?? Am I looking at another column, if so, are the Trimatic column shift columns the same, I hope so, there's more of these around!!
Peter
#2 Posted : Monday, 6 September 2004 10:36:45 PM(UTC)
I'm 99% sure the columns are the same. I've converted a HJ column TH400 to a column trimatic before, and you only have to change it from the column lower arm where the shift rod attaches to the gearbox.
#3 Posted : Tuesday, 7 September 2004 12:25:13 AM(UTC)
Thanks for that, seems I may have found the problem, I may have either fitted the aftermarket wheel too tight or too loose as I can move the lever forward to lift over the gate, but the steering wheel moves towards the column at the same time.
Peter
#4 Posted : Wednesday, 25 May 2005 11:22:34 PM(UTC)
i was wondering how do you fix the column in the hz from coming out about 6 inches past the casing basically the steering column comes out about 6 inches but stops and i was wondering how to fix it
#5 Posted : Thursday, 26 May 2005 3:42:14 AM(UTC)
You can't Dale AFAIK. It sounds like you have broken the tabs that hold the column at the correct length but break in an accident allowing the column to collapse instead of impaling you.
You need another column.
Cheers...Dave
classic oz wreck Offline
#6 Posted : Thursday, 26 May 2005 6:14:55 AM(UTC)
classic oz wreck
column is the same as any column auto...t400 stuff is unique from the base of the column only...linkages etc...
www.classicozwreck.com.au
Guest (5)
