chevman Offline
#1 Posted : Thursday, 12 July 2007 6:50:26 AM(UTC)
chevman
hey guys i have a 307 chev that has been freshnd up! i will start at the top, the heads have been done up for unleaded, has a 4b manifold, electronic dizzy, brand new cam and lifters cam is mild, new rings and bearings from memory it has been bored 40thou, obviously has new timeing gears and chain, chrome timeing cover, comes with alternator and bracket, water pump, starter motor engine mounts and cross member for t350 to go into hq B&M shifter, exstractors to go into hq, all engine needs is welshplugs as it hasnt been started since all has been done reason for sale is i cant be botherd with vicroads and all the **** to put it in a hz!
Im asking $1000 for the lot ono it is located south gippsland either post here or contact me on 0437813793 cheers! Dean
engine no first 7 numbers 3074054 Cast no 3914636
Edited by user Tuesday, 17 July 2007 4:25:15 AM(UTC)  | Reason: Not specified
IF YOU WANT MORE INCHES STROKE IT!!!
#2 Posted : Thursday, 12 July 2007 7:53:16 AM(UTC)
what sort of power do u think it will get?
chevman Offline
#3 Posted : Thursday, 12 July 2007 8:58:45 AM(UTC)
chevman
Hqmonaro to be honest i have no idea, maybe one of the guys on here may have some idea, it hasnt been realy worked so it probly wouldnt be a great deal more than standard, the cam and elctronic dizzy may make a bit of difference but ir ealy cant help you
80737k Offline
#4 Posted : Friday, 13 July 2007 2:09:16 AM(UTC)
80737k
Two hours south of Melbourne would put you somewhere near....Tasmania ?
Ooroo
Fossil fuels are YUMMY !
#5 Posted : Friday, 13 July 2007 4:23:27 AM(UTC)
wher the hell are you from? or do you fly a jet?
chevman Offline
#6 Posted : Sunday, 15 July 2007 4:19:57 AM(UTC)
chevman
A push bike with wings, home made! south of melbourne= south gippsland! if your not intrested then dont bother posting!
hazzard county Offline
#7 Posted : Sunday, 15 July 2007 7:03:53 AM(UTC)
hazzard county
sounds like a good offer can you tell us what the engine cast number & engine number is thanks
chevman Offline
#8 Posted : Sunday, 15 July 2007 8:42:14 AM(UTC)
chevman
I can do that hazzard county, where will i find the cast number? is that at the front of the block above the timeing cover? for all i know i may have a 307 thats out of a hk monaro it was in a bedford truck when i purchased it! cheers
#9 Posted : Sunday, 15 July 2007 10:01:55 AM(UTC)
hazzard county
the cast number should be on the rear l/h side just behind the head & engine number should be front r/h side in front of the head dont post the full engine number just in case someone decides to use your engine number eg should have 8 numbers 30775645 & a
80737k Offline
#10 Posted : Sunday, 15 July 2007 10:41:25 AM(UTC)
80737k
#11 Posted : Tuesday, 17 July 2007 6:09:55 AM(UTC)
hazzard county
gday mate you seem to be on a winner i cross ref & the engine seems to be for an early built hk monaro premier or brougham from the dandenong plant melbourne but i stand corrected
chevman Offline
#12 Posted : Tuesday, 17 July 2007 10:18:35 PM(UTC)
chevman
thanks mate, What would be my best next step in finding out what its actualy from if possible? would more numbers help you out? cheers
#13 Posted : Wednesday, 18 July 2007 1:36:47 AM(UTC)
hazzard county
gday bloke thats about all i can tell you the remainder of the numbers will tell you which plant the block was cast i'd say canada if it has the k on it .if you go to holden forum on this web site some one should be able to tell you more but i think thats
This page was generated in 0.114 seconds.
