#1 Posted : Friday, 13 July 2007 5:51:44 AM(UTC)
hey all what do you think is the best combo for me.
its going in a hg. my thorts are.
vn efi v8 and t700
vn efi v8 and t350
307 or 327 and t350 or power slide
i want fast take off (lots of smoke) and sum hiway driving.
peter_flane Offline
#2 Posted : Friday, 13 July 2007 6:17:56 AM(UTC)
peter_flane
The first one will be a nice combo.
#3 Posted : Friday, 13 July 2007 6:28:37 AM(UTC)
I'd go the second if you want it easy and cheap, plus you can use up to a 2000 model VSIII engine, not just VN.
iitsmint Offline
#4 Posted : Friday, 13 July 2007 7:51:32 AM(UTC)
iitsmint
253 trumatic !
JBM Offline
#5 Posted : Friday, 13 July 2007 7:55:50 AM(UTC)
JBM
A Chevy will be cheaper to build and has TPI available if you want injection. It will bolt up to a TH350 or a Chev powerglide without having to worry about bolt holes and dowel positions. You could also use the TH700 with the lockup convertor for the high
musksell Offline
#6 Posted : Friday, 13 July 2007 8:57:05 AM(UTC)
musksell
You need a hell of, a lot of torque for a 3 speed, especially if you are towing anything.You can get a higher top gear and a similar lower ratio with 4 speed auto. 5 litre EFI T700.
#7 Posted : Friday, 13 July 2007 4:20:12 PM(UTC)
You can't tow in top gear in an original TH700, that is one of their weaknesses.
I'd still stick with the TH350 because:
They are stronger and heaps less problem;
Uses HT/HG V8 powerglide crossmember;
Uses HK/HG V8 powerglide/trimatic/manual tailshaft
