boom Offline
#1 Posted : Monday, 16 July 2007 7:02:05 AM(UTC)
boom
guys, what would be a welcome addition to the rear of my VK? at the moment it has standard drums, but i want discs for the rebuild in anticipation of fitting a V8.
Yeh ive thought about a VT rear upgrade, but the cost is very high.
Are the V8 standard brakes any good? ive heard weird stories about them.
and are the VL turbo front calipers a good upgrade from the standard fronts, and will they bolt up no probs?
If it doesn’t burn fossil fuels, it’s not a sport.
#2 Posted : Monday, 16 July 2007 10:08:00 PM(UTC)
I think the rear discs remained the same from VB through to the end of 2000 on the VSIII ute.
Basically if you convert your VK to a 5litre you'll have to upgrade to a 10-bolt Salisbury (unless you want to be chewing up 6cyl diffs) and on a Commodore thes
#3 Posted : Monday, 16 July 2007 10:08:00 PM(UTC)
Basically if you convert your VK to a 5litre youll have to upgrade to a 10-bolt Salisbury (unless you want to be chewing up 6cyl diffs) and on a Commodore these
boom Offline
#4 Posted : Tuesday, 17 July 2007 3:28:16 AM(UTC)
boom
does the diff need to be shortened if i choose to use the LSD from a middle gen commodore?
boom Offline
#5 Posted : Tuesday, 17 July 2007 3:29:10 AM(UTC)
boom
oh and are the VL turbo calipers beigger than the standard VK SL calipers?
#6 Posted : Tuesday, 17 July 2007 4:13:24 AM(UTC)
Im not 100% sure, but if you use the VL diff they use the same centre as the later commodores AFAIK.
The front brakes are bigger on a VL V8 or turbo, but I think the rears are the same as all other pre VT.
_____________________________________________
#7 Posted : Tuesday, 17 July 2007 4:13:24 AM(UTC)
I'm not 100% sure, but if you use the VL diff they use the same centre as the later commodores AFAIK.
boom Offline
#8 Posted : Wednesday, 18 July 2007 3:43:45 AM(UTC)
boom
will HQ - WB rear calipers fit onto a VK salisbury V8 diff, ive located one to fit to my VK, but it doesnt have the calipers, just discs
Edited by user Wednesday, 18 July 2007 3:47:49 AM(UTC)  | Reason: Not specified
boom Offline
#9 Posted : Wednesday, 18 July 2007 3:43:45 AM(UTC)
boom
will HQ - WB rear calipers fit onto a VK salisbury V8 diff, ive located one to fit to my VK, but it doesn't have the calipers, just discs
#10 Posted : Wednesday, 18 July 2007 4:38:43 AM(UTC)
No. You wont have any trouble finding some though. I think they are the same from VB to VSIII, regardless of 6cyl or V8 - anyone confirm?
If we all had the same (good) taste, who would buy all th
#11 Posted : Wednesday, 18 July 2007 4:38:43 AM(UTC)
No. You won't have any trouble finding some though. I think they are the same from VB to VSIII, regardless of 6cyl or V8 - anyone confirm?
#12 Posted : Wednesday, 18 July 2007 5:33:34 AM(UTC)
Hi Guys.
Yes, the rear disc set-up remained basically unchanged from VB to VS III, with a few exceptions. Ignore the HSV 'Premium' package, (VN Group A, SV5000 etc) these use 2-piston calpiers & vented disc rotors. Also IRS cars disc rotors are slightl
#13 Posted : Wednesday, 18 July 2007 5:33:34 AM(UTC)
Hi Guys.
Yes, the rear disc set-up remained basically unchanged from VB to VS III, with a few exceptions. Ignore the HSV Premium package, (VN Group A, SV5000 etc) these use 2-piston calpiers & vented disc rotors. Also IRS cars disc rotors are slightly
boom Offline
#14 Posted : Wednesday, 18 July 2007 5:56:02 AM(UTC)
boom
ok i think i get it.
so, any caliper from VB - VS III will fit, but i have to be wary of the backing plate. what do i need to do to resolve this if i decide to go with a caliper from VN onwards?
#15 Posted : Wednesday, 18 July 2007 6:31:30 AM(UTC)
Nothing. Terry is just telling you that the backing plate of the disc hub changed after VL. The calipers are the same.
boom Offline
#16 Posted : Wednesday, 18 July 2007 7:13:34 AM(UTC)
boom
oh ok cool. Can anyone tell me what tailshaft is needed for a 5spd with a V8 salisbury diff?
#17 Posted : Wednesday, 18 July 2007 11:24:33 PM(UTC)
Alex I would say that you will need a custom tailshaft to go from a VK 5 speed box to a V8 diff. Also if you upgrade to the VL turbo/V8 front calipers you will also have to upgrade your front wheels to 15" minimum.
I believe that any VP2 has these b
boom Offline
#18 Posted : Sunday, 22 July 2007 7:17:48 PM(UTC)
boom
does anyone know for sure whether i would need a custom tailshaft?
#19 Posted : Tuesday, 24 July 2007 7:41:33 AM(UTC)
No you don't need a custom tail shaft if your VK has a Borgy diff(late 85 on).
You can separate the tailshafts where they bolt together with the allen key bolts. Then you can fit the 5 speed front section to a V8 or EFI 6 rear section. This will bolt up
#20 Posted : Tuesday, 24 July 2007 7:41:33 AM(UTC)
No you dont need a custom tail shaft if your VK has a Borgy diff(late 85 on).
You can separate the tailshafts where they bolt together with the allen key bolts. Then you can fit the 5 speed front section to a V8 or EFI 6 rear section. This will bolt up t
Guest (9)
This page was generated in 0.093 seconds.
