#1 Posted : Monday, 16 July 2007 9:13:32 AM(UTC)
I have a VP sedan v6 speedway car and need to get a higher diff ratio then i currently have(3.08). Does anyone know what is available and/or if a earlier model would fit ?
AnthonyH
#2 Posted : Monday, 16 July 2007 6:03:09 PM(UTC)
Hi Anthony.
A higher ratio which way? Higher geared, meaning a lower number, or lower geared, meaning a higher number. e.g. 3.70 is a higher number but it is a lower gear.
Anyway after all that, the VN/VP diff is a B/W 78 series & there are many gea
#3 Posted : Monday, 16 July 2007 8:38:02 PM(UTC)
Thanks Dr Terry. I am looking to go hihger geared as we are hitting the rev limiter about 3/4s of the straight. What is the hemisphere that you said will need changing?
thanks again
CSR21
#4 Posted : Tuesday, 17 July 2007 1:29:01 AM(UTC)
thanks again
CSR21
CSR21
#5 Posted : Wednesday, 18 July 2007 11:05:37 PM(UTC)
2.92:1 is a very common ratio in Ford diffs. The 2.77:1 is also common but will require a different hemisphere (crownwheel carrier) due to the larger pinion gear requiring the crownwheel to be mounted further across.
HTH Jim...
