WhiteKnight Offline
#1 Posted : Wednesday, 18 July 2007 10:57:14 PM(UTC)
WhiteKnight
Hi guys,
I'm a bit of a noob when it comes to old Holdens as I've only been into modern Japanese sports cars in the past.
I've got a 1966 HR Special with a 202 conversion and Trimatic with floor shifter. I don't like the way it revs high when cruising with only 3 gears and the fuel suffers I think because of this.
Is there a 4 speed automatic that bolts to the 202 at all?
A mate of mine with a SLR5000 replica suggested a different diff ratio as he runs an auto with a 3.55 diff and he said it's quite economical on fuel.
Kind regards,
Chris.
1966 HR Special
202 with Trimatic
1966 HR Special
202 with Trimatic
My 1966 HR Special
peter_flane Offline
#2 Posted : Thursday, 19 July 2007 4:55:52 AM(UTC)
peter_flane
What diff are you running? Maybe a 3.55 or 3.36?
Changing to a 3.08 diff would be the quickest easiest option to get less revs on the highway.
#3 Posted : Thursday, 19 July 2007 7:15:07 AM(UTC)
if you really want a 4 speed best just to transplant entire engine and trans from a vl commodore.
#4 Posted : Thursday, 19 July 2007 7:58:10 AM(UTC)
I thought the same thing but using a better engine - the VN/VP 3.8 and TH700R4. However I have heard of an adapter for the TH700 to Holden 6. Try Mal Wood in QLD or CRS in Victoria.
If we all had
musksell Offline
#5 Posted : Thursday, 19 July 2007 9:29:27 AM(UTC)
musksell
A vn/vp a better engine than the 3 litre Nissan engine ?
...come on Byron...!!
The Nissan is alot better build quality...!! and will last heaps longer...as heaps of them already have....
The other side of the coin is ....A Holden should have a
peter_flane Offline
#6 Posted : Thursday, 19 July 2007 9:35:29 AM(UTC)
peter_flane
Just a personal opinion. I would not put a Nissan/ VL or a V6 3.8 engine in an old Holden. Ever.
A 202 is a good cruiser, and can be used as a reliable everyday engine. Easy to fit to old Holden as you can see as you have one. If I wanted power I would
WhiteKnight Offline
#7 Posted : Thursday, 19 July 2007 10:14:46 AM(UTC)
WhiteKnight
1966 HR Special
202 with Trimatic
My 1966 HR Special
WhiteKnight Offline
#8 Posted : Thursday, 19 July 2007 10:17:13 AM(UTC)
WhiteKnight
Th
Edited by user Thursday, 19 July 2007 9:38:18 PM(UTC)  | Reason: Not specified
1966 HR Special
202 with Trimatic
My 1966 HR Special
#9 Posted : Thursday, 19 July 2007 4:20:08 PM(UTC)
Th
vulcan2509 Offline
#10 Posted : Thursday, 19 July 2007 4:56:53 PM(UTC)
vulcan2509
All that has been said is all good info but you gotta ask yourself what you want from your HR and how much money and time your prepared to give up. If you want a quick fix go for changing your diff centre if that doesn't solve your problem an engine trans
"With A Name Like Brock What Else Would I Drive"
HQwagon202 Offline
#11 Posted : Thursday, 19 July 2007 10:47:05 PM(UTC)
HQwagon202
hi
i also own a warm 6 cylinder holden (202) and have thought about a turbo 700 4 speed automatic behind the 6 cylinder.
Some time ago i contacted Wholesale automatics in Melbourne, i however live in Sydney, to see if in fact it was possible to do t
WhiteKnight Offline
#12 Posted : Friday, 20 July 2007 12:32:39 AM(UTC)
WhiteKnight
Originally posted by HQwagon202
hi
Edited by user Saturday, 21 July 2007 4:26:53 AM(UTC)  | Reason: Not specified
1966 HR Special
202 with Trimatic
My 1966 HR Special
WhiteKnight Offline
#13 Posted : Friday, 20 July 2007 12:41:36 AM(UTC)
WhiteKnight
1966 HR Special
202 with Trimatic
My 1966 HR Special
HQwagon202 Offline
#14 Posted : Friday, 20 July 2007 4:51:24 AM(UTC)
HQwagon202
i remember talking to Geoff Dellow from Dellow Automotive, he informed me at the time that he can make, or does make and adaptor plate to fit the turbo 700 box onto the red 6.
That may help you
regards
peter_flane Offline
#15 Posted : Friday, 20 July 2007 6:04:38 AM(UTC)
peter_flane
A 4 speed manual will still have the same top gear and the same revs on the highway!
A 4 speed auto T700 has overdrive on top gear.
Manual gearboxes have 5th gear as overdrive.
Your easiest option in manual would be a Celica 5 speed conversion. P
#16 Posted : Friday, 20 July 2007 4:34:26 PM(UTC)
Another easy solution, since you already have a trimatic, stick an Aussie 4spd M22 (fits where a trimatic fits) in it and run a 2.78 diff. Just don't do it with an M20 or you'll hate 1st gear.
If
WhiteKnight Offline
#17 Posted : Tuesday, 24 July 2007 9:34:28 PM(UTC)
WhiteKnight
Thanks for your help everyone
1966 HR Special
202 with Trimatic
[URL="http://www.fastlane.com.au/forums/topic.asp?TOPIC_ID=12326"]My 1966 HR Special[/URL]
1966 HR Special
202 with Trimatic
My 1966 HR Special
This page was generated in 0.130 seconds.
