Hi guys, I'm a bit of a noob when it comes to old Holdens as I've only been into modern Japanese sports cars in the past. I've got a 1966 HR Special with a 202 conversion and Trimatic with floor shifter. I don't like the way it revs high when cruising with only 3 gears and the fuel suffers I think because of this. Is there a 4 speed automatic that bolts to the 202 at all? A mate of mine with a SLR5000 replica suggested a different diff ratio as he runs an auto with a 3.55 diff and he said it's quite economical on fuel. Kind regards, Chris.
1966 HR Special 202 with Trimatic |
What diff are you running? Maybe a 3.55 or 3.36?
Changing to a 3.08 diff would be the quickest easiest option to get less revs on the highway. |
if you really want a 4 speed best just to transplant entire engine and trans from a vl commodore.
I thought the same thing but using a better engine - the VN/VP 3.8 and TH700R4. However I have heard of an adapter for the TH700 to Holden 6. Try Mal Wood in QLD or CRS in Victoria.
_______________________________________________________ If we all had |
A vn/vp a better engine than the 3 litre Nissan engine ? ...come on Byron...!! The Nissan is alot better build quality...!! and will last heaps longer...as heaps of them already have.... The other side of the coin is ....A Holden should have a
Just a personal opinion. I would not put a Nissan/ VL or a V6 3.8 engine in an old Holden. Ever.
A 202 is a good cruiser, and can be used as a reliable everyday engine. Easy to fit to old Holden as you can see as you have one. If I wanted power I would |
Changing to a 3.08 diff would be th |
quote: Originally posted by musksell
A vn/vp a better engine than the 3 litre Nissan engine ? ...come on Byron...!! ThEdited by user Thursday, 19 July 2007 9:38:18 PM(UTC)
| Reason: Not specified |
A vn/vp a better engine than the 3 litre Nissan engine ? ...come on Byron...!! Th |
All that has been said is all good info but you gotta ask yourself what you want from your HR and how much money and time your prepared to give up. If you want a quick fix go for changing your diff centre if that doesn't solve your problem an engine trans |
"With A Name Like Brock What Else Would I Drive" |
hi
i also own a warm 6 cylinder holden (202) and have thought about a turbo 700 4 speed automatic behind the 6 cylinder.
Some time ago i contacted Wholesale automatics in Melbourne, i however live in Sydney, to see if in fact it was possible to do t
quote: Originally posted by HQwagon202
hi
i also own a warm 6 cylinder holden (202) and have thought about a turbo 700 4 spEdited by user Saturday, 21 July 2007 4:26:53 AM(UTC)
quote: Originally posted by vulcan2509
All that has been said is all good info but you gotta ask yourself what you want from y |
i remember talking to Geoff Dellow from Dellow Automotive, he informed me at the time that he can make, or does make and adaptor plate to fit the turbo 700 box onto the red 6.
That may help you
regards
A 4 speed manual will still have the same top gear and the same revs on the highway!
A 4 speed auto T700 has overdrive on top gear.
Manual gearboxes have 5th gear as overdrive.
Your easiest option in manual would be a Celica 5 speed conversion. P |
Another easy solution, since you already have a trimatic, stick an Aussie 4spd M22 (fits where a trimatic fits) in it and run a 2.78 diff. Just don't do it with an M20 or you'll hate 1st gear.
_______________________________________________________ If |
Thanks for your help everyone
1966 HR Special 202 with Trimatic [URL="http://www.fastlane.com.au/forums/topic.asp?TOPIC_ID=12326"]My 1966 HR Special[/URL] |
