3 Pages<123>
jimmy64 Offline
#21 Posted : Saturday, 13 October 2007 5:53:31 AM(UTC)
jimmy64
Hi Gentlemen, Im new to this site and require a little guidance. I have been blessed to have been able to purchase a 307 (30775019K0104) GTS 68 HK in pieces with the original rego plates and engine. HOWEVER the tags are gone, but I have known the car was
jimmy64 Offline
#22 Posted : Saturday, 13 October 2007 5:53:31 AM(UTC)
jimmy64
Hi Gentlemen, I'm new to this site and require a little guidance. I have been blessed to have been able to purchase a 307 (30775019K0104) GTS 68 HK in pieces with the original rego plates and engine. HOWEVER the tags are gone, but I have known the car was
#23 Posted : Saturday, 13 October 2007 5:32:48 PM(UTC)
Without any tags or books it is impossible to check a vehicles credentials.
Warren
#24 Posted : Saturday, 13 October 2007 6:53:23 PM(UTC)
Thanks Warren, so wouldnt the rego give it a bit of credence? The old disc is still on the windscreen from 1988 and I have the renewal form from then that shows the colour and trim (trim appears to be original albeit in poor condition)and given that back
#25 Posted : Saturday, 13 October 2007 6:53:23 PM(UTC)
Thanks Warren, so wouldn't the rego give it a bit of credence? The old disc is still on the windscreen from 1988 and I have the renewal form from then that shows the colour and trim (trim appears to be original albeit in poor condition)and given that back
#26 Posted : Sunday, 14 October 2007 1:11:45 AM(UTC)
Was thanked: 605 time(s) in 572 post(s)
All the rego history will tell you is the chassis number and engne number both of which you have already. The other numbers will remain a mystery, unless you can find who took them.
If we all had
#27 Posted : Sunday, 14 October 2007 4:26:36 AM(UTC)
Rego only tells you exterior colour not interior colour, and once again it has to be the original rego as a colour change in the 70s was a full on job, very IN to have a bare metal respray in those days, then change the colour on the rego papers and you
jimmy64 Offline
#28 Posted : Tuesday, 20 November 2007 8:18:38 AM(UTC)
jimmy64
another question for the experts, on the firewall is stamped HK 20787 A. I assume this means it is an Adelaide car can anything else be gleaned from this??
#29 Posted : Tuesday, 20 November 2007 4:03:58 PM(UTC)
It's a HK. That's all apart from built in Elizabeth as you already stated. If you know the build date of other Elizabeth HK's around the same number you can also estimate the build date.
If we al
#30 Posted : Tuesday, 20 November 2007 4:03:58 PM(UTC)
Its a HK. Thats all apart from built in Elizabeth as you already stated. If you know the build date of other Elizabeth HKs around the same number you can also estimate the build date.
If we all h
#31 Posted : Wednesday, 21 November 2007 5:53:04 AM(UTC)
Thanks Byron any ideas how I find the build date of other HK's? Can I also assume (I know that is dangerous) that as the speedo cable entry in the firewall is in the centre, that is is more than likely an original V8? Sorry to ask so many questions but I
#32 Posted : Wednesday, 21 November 2007 5:53:04 AM(UTC)
Thanks Byron any ideas how I find the build date of other HKs? Can I also assume (I know that is dangerous) that as the speedo cable entry in the firewall is in the centre, that is is more than likely an original V8? Sorry to ask so many questions but I a
#33 Posted : Wednesday, 21 November 2007 4:10:18 PM(UTC)
I think your assumption is correct. All V8 HK had the speedo cable hole in the centre. BUT you could order a Saginaw behind a 6cyl, although this is rare. A 10-bolt hump also means V8 mostly, but you could also order a 10 bolt behind a 6cyl I think - Warr
#34 Posted : Wednesday, 21 November 2007 5:25:05 PM(UTC)
10 bolt only available on 6 cylinder from HQ on, not HK to HG.
#35 Posted : Tuesday, 27 November 2007 12:37:42 PM(UTC)
G'day guys, Ive been reading so much information on this forum its mind blowing to hear the amount of knowledge some of you out there have. So ive got afew questions about hk gts monaro's that if anyone could help me out with that would be much appreciate
#36 Posted : Tuesday, 27 November 2007 12:37:42 PM(UTC)
Gday guys, Ive been reading so much information on this forum its mind blowing to hear the amount of knowledge some of you out there have. So ive got afew questions about hk gts monaros that if anyone could help me out with that would be much appreciated.
#37 Posted : Tuesday, 27 November 2007 4:08:04 PM(UTC)
1. Not on the car, but on individual components, either stamped or painted. Example, steering box, top left corner viewed from the front. Steering column.
2. Neither. Only from 1/70 did the HT gain a 3rd tag (ADR tag) and then the chassis number appears
#38 Posted : Tuesday, 27 November 2007 5:18:46 PM(UTC)
Impossible to get HT interior in HK, as back seat is different, plus the pading on front seat is also different.
Warren
jimmy64 Offline
#39 Posted : Wednesday, 28 November 2007 7:11:02 AM(UTC)
jimmy64
Hi Byron and Warren,I'm a bit like Matt, reading lots of great info, thanks, so if my car is an original, you are saying the steering box will have the build date on it? When you say viewed from the front does this mean I have to remove it to see it? (I c
jimmy64 Offline
#40 Posted : Wednesday, 28 November 2007 7:11:02 AM(UTC)
jimmy64
Hi Byron and Warren,Im a bit like Matt, reading lots of great info, thanks, so if my car is an original, you are saying the steering box will have the build date on it? When you say viewed from the front does this mean I have to remove it to see it? (I ca
3 Pages<123>
