#1 Posted : Tuesday, 24 July 2007 11:07:01 AM(UTC)
Is there a difference in the 6 cyl &8 cyl tacho. If so can the 6 cyl be made to work on an 8 cyl motor.
#2 Posted : Tuesday, 24 July 2007 4:09:37 PM(UTC)
it may have a switch on it, the HQ type tacho has a switch from 6-8cyl from memory.
#3 Posted : Tuesday, 24 July 2007 8:34:26 PM(UTC)
The HK GTS tacho is a standard tacho that has a switch for 6/8/12 cylinders, they are marked as 6 and V8 on the bottom plate but just pull the tacho out and change the switch.
Warren
#4 Posted : Tuesday, 24 July 2007 11:31:30 PM(UTC)
When the HK parts catalogue listed 2 different part numbers I presumed they would be different. Any reason they list 1 part number for the 161/186 and 1 for the 307/327. Thanks for the info Warren and Cloudy. Cheers.
#5 Posted : Wednesday, 25 July 2007 12:09:20 AM(UTC)
So that you do not have to pull it apart to change the setting, as they come in the boot, so easentially sealed. The plate on the bottom has a 6 or 8 stamped on it.
If you go through the parts book you will find that the boot is not sold seperately, it
