basketcasebear Offline
#1 Posted : Sunday, 29 July 2007 3:48:56 AM(UTC)
basketcasebear
I know you have all been waiting, for another pearler of a question, from yours truly, here tis,
how does and air conditioner unit, compress the gas??
is it like a nail gun compressor, with a little piston, or some other mechanical way of compressing the gas?
thanks already
ptpro
DOH!!!
peter_flane Offline
#2 Posted : Monday, 30 July 2007 5:52:53 AM(UTC)
peter_flane
They are a rotary compressor. There are several types of rotary compressor, and a supercharger is one of them also. They are a lobe or screw type. The air conditioner unit would be an eccentric rotor type I would assume.
#3 Posted : Monday, 30 July 2007 7:17:20 AM(UTC)
The older (at least) Ford and Chrysler are piston types. Frigidaire (GM) is rotary
#4 Posted : Tuesday, 31 July 2007 9:22:55 AM(UTC)
basketcasebear
oh good,,,i now know what i can adapt an old aircon compressor too,
hey thanks fella,s
ptpro
DOH!!!
peter_flane Offline
#5 Posted : Wednesday, 1 August 2007 4:43:33 AM(UTC)
peter_flane
Adapt it for?
Pneumatic diff lock? Air bags? Air shocks? Pumping tyres? Secret?
hz dude Offline
#6 Posted : Wednesday, 1 August 2007 6:35:24 AM(UTC)
hz dude
I have a uncle with a 2 tonner that wants to put air tank
under the tray for a nailgun for work he was woundering
if it can be with a aircon compressor how is it done ?
will it run a nailgun with a 50lt tank ?
sorry to change the suject abit
it'
hz dude Offline
#7 Posted : Wednesday, 1 August 2007 6:35:24 AM(UTC)
hz dude
its
#8 Posted : Wednesday, 1 August 2007 8:46:46 AM(UTC)
basketcasebear
hey hz dude,, this is what i like to see!!! lateral thinking!!
i am a retired carpenter and it seems a great idea? dont know how much pressure they will create? if you were really cluey, you could rig it up to only compress the gas,,/air/ when you put
DOH!!!
#9 Posted : Wednesday, 1 August 2007 10:03:44 AM(UTC)
I thought of doing this a while ago to pump up tyres quickly, but it has a flaw in that the aircon compressor gas contains the lubricating oil.
If you can devise a lubricating method it should be ok I think. Maybe a drip feed somehow.
#10 Posted : Wednesday, 1 August 2007 10:17:51 AM(UTC)
basketcasebear
hhhmmm? we need a compresssor that stores braking energy, and then gives it back to drive the car?? and pump up the tyres, and operate the nail gun?
and cool the beer?? hhhmmmm!!!!! doh!!
ptpro
DOH!!!
jabba Offline
#11 Posted : Wednesday, 1 August 2007 3:05:23 PM(UTC)
jabba
johnperth, One of the guys inn our 4wd club has this exact setup on a hilux ute
The aircon compressor is in place, but with all piping removed. Instead, the compressor pumps into a short length of tube with a quick release air hose fitting. To pump u
Mr Void Offline
#12 Posted : Thursday, 2 August 2007 5:39:31 AM(UTC)
Mr Void
As far as triggers go, there is a kit that jaycar sell that turns the air-con OFF when under full throttle. Im sure it wouldnt take a rocket scientist to work out how to mod a kit like that to make it turn on when the h.brake is engaged and off when dise
___________________
Mr Void Offline
#13 Posted : Thursday, 2 August 2007 5:39:31 AM(UTC)
Mr Void
As far as triggers go, there is a kit that jaycar sell that turns the air-con OFF when under full throttle. I'm sure it wouldn't take a rocket scientist to work out how to mod a kit like that to make it turn on when the h.brake is engaged and off when di
___________________
#14 Posted : Thursday, 2 August 2007 7:55:27 AM(UTC)
basketcasebear
hey mr void, what i was tinkin, was a compressor that comes on when you put your foot on the brake, helping to brake the vehicular movement, and then use this stored energy, to drive the veehikle, ?? as well as cool the beer, operate the nail gun, and pu
DOH!!!
#15 Posted : Thursday, 2 August 2007 10:33:10 AM(UTC)
The old style compressors like those on the hq etc were a piston type unit which would be ideal for this purpose, I have a couple of them I picked up at the local rubbish type to experiment with. they look like a lawn mower engine. in fact a lawn mower or
#16 Posted : Friday, 3 August 2007 12:27:52 AM(UTC)
basketcasebear
BRILIANT!!!! john perth,,,what we need is a diff with a power take off out the back, with a small clutch, so when brake pedal is pushed, engages small motor, compressors air, helping to slow vehickle, then when pushing accelerator, air is forced back in
DOH!!!
#17 Posted : Friday, 3 August 2007 9:53:07 AM(UTC)
he he Have you been on the bizarro juice or something?
where would you store the air till you need it?
Anyway just remembered the small engine would have to be 4 stroke as 2 strokes dont have sump for oil, so chainsaws definitely out.
#18 Posted : Friday, 3 August 2007 9:53:07 AM(UTC)
Anyway just remembered the small engine would have to be 4 stroke as 2 strokes don't have sump for oil, so chainsaws definitely out.
wantree Offline
#19 Posted : Friday, 3 August 2007 10:15:31 AM(UTC)
wantree
Just need to put 12 volts onto the clutch wire!! (only wire going to the compressor). You could achieve that any way you like!
#20 Posted : Friday, 3 August 2007 10:16:36 AM(UTC)
basketcasebear
john perth,, store it in a tank,,, i truly dont know why they dont have power take off,s with diffs, like tractors do?
or someone hasnt designed an adaptor kit for one? then it would be easy, just bolt engine onto shaft at back of diff? with small clutc
DOH!!!
Guest (5)
This page was generated in 0.106 seconds.
