Handgunner Offline
#1 Posted : Sunday, 29 July 2007 7:29:09 PM(UTC)
Handgunner
Hi folks, i have a problem... my 186 will not idle properly ..its running on gas at the moment.. is there a way that i can adjust the idle / gas mixture ? I have a spudded stromberg and the car runs fine down the hi way ... i am assuming that it is too lean in its idle circuit / mixture? I dont really know... what does the metal restrictor in the main gas line from convertor do ?
Thanx in advance...
Anthony
Bang Bang
Bang Bang
#2 Posted : Tuesday, 31 July 2007 4:38:31 AM(UTC)
HI, bang bang the screw type restrictor in the line from the convertor to the mixer is the main power valve,like a tap controls the gas flow, if you can get it to run at about 3000rpm wind it out till the rpm increases then turn it back a few turns, you c
Rockett Offline
#3 Posted : Tuesday, 31 July 2007 11:24:12 PM(UTC)
Rockett
Hi, Handgunner
I too reciently have the same issue on a Gas powered VK 202. It idles like a dog and lacks power. I pulled one lead off at a time (trying to isolate a cylinder) but it makes no difference to the car.
Changed plugs, dizzy cap, leads and al
hx-sandman Offline
#4 Posted : Friday, 3 August 2007 2:37:07 AM(UTC)
hx-sandman
I had the same issue with a 308 on gas - the system was stifling any air flow and it ran like a piece of crap. Solved the problem by getting rid of the gas and going to straight petrol. Runs much better :-)
wantree Offline
#5 Posted : Friday, 3 August 2007 10:23:20 AM(UTC)
wantree
Check the hose integrity between the mixer and vapouriser and also diapham in mixer as vacuum drives these and small leaks at low rpms can cause mayhem. Thats the beauty of dual fuel as most everything complex can be eliminated by the car running good on
Handgunner Offline
#6 Posted : Friday, 3 August 2007 9:57:19 PM(UTC)
Handgunner
Thanks for all of the good advice... i will now check for any minor leaks and try the adjustments... cheers to all :)
Bang Bang
Bang Bang
