#1 Posted : Monday, 30 July 2007 6:57:48 AM(UTC)
Hi Guys,
I am having a few issues with my Vectra.
It is a 1998 Holden Vectra GL JS 1 with 173000KMS
Took it in for a service the other day and I asked them to check out the Coolant Reservoir as it was losing coolant and the car was also vibrating on start up until I hit about 1100RPM.
They said that the Head Gasket was leaking into the Cooling System and this is why I was losing the coolant.
Anway, I was just wondering how much you all think this might cost to get fixed? I have had to have the cars head gasket replaced once before but I dont know if it was leaking into the cooling system last time as I wasn't losing coolant? If it is too expensive I might just look at selling it as is, hopefully I should get about $5000.00 for it as is.
Thanks for your help Guys.
trubluhq Offline
#2 Posted : Monday, 30 July 2007 8:16:32 AM(UTC)
trubluhq
Hi Adam,
(1) Ask GMH what it will cost to fix. Thats the best solution. It cant be THAT expensive.
(2) If its too pricey sell the car.
(3) WIth teh $5000 you get from the VECTRA buy a good HQ V8 (4.2 or 5.0). No emission laws, huge boot, run well, sound great and the cost of a gasket pair is around $30.00. You can also get parts from Kmart, AutoOne, or Repco Sat/Sun Arvo. You wont get that service from GMH.
Cheers John
trubluhq Offline
#3 Posted : Monday, 30 July 2007 8:16:32 AM(UTC)
trubluhq
Hi Adam,
#4 Posted : Monday, 30 July 2007 3:13:34 PM(UTC)
Hey John,
So you think all I need to do is replace the head gasket and all will be good?
#5 Posted : Monday, 30 July 2007 3:13:34 PM(UTC)
Hey John,
#6 Posted : Monday, 30 July 2007 3:14:49 PM(UTC)
Oh, Also, KMART Tyre and Auto advised me it would cost about $1500 - $2500 to fix.
#7 Posted : Monday, 30 July 2007 3:14:49 PM(UTC)
HK1837 Online
#8 Posted : Monday, 30 July 2007 4:20:49 PM(UTC)
Adam. The head may be warped or damaged, especially so if the head gasket was changed before indicating previous overheating problems? Have you kept coolant/corrosion inhibitor up to it with regular servicing? It may also be corroded as a result meaning a
HK1837 Online
#9 Posted : Monday, 30 July 2007 4:20:49 PM(UTC)
Adam. The head may be warped or damaged, especially so if the head gasket was changed before indicating previous overheating problems? Have you kept coolant/corrosion inhibitor up to it with regular servicing? It may also be corroded as a result meaning a new/replacement head.
Where are you? Id definitely get further advice though. $2500 sounds steep though, but id not be surprised if it cost you well over $1000 to repair. All said, youd probably get a good secondhand engine fitted for less than $1500 and with less kM.
trubluhq Offline
#10 Posted : Monday, 30 July 2007 8:16:18 PM(UTC)
trubluhq
If it were just laking then prob just the gasket. Teh shuddering worrier me a bit.
WHat colour and consistency is the engine oil ?? Does it look normal or like MILO ?? If MILO like the water is in the oil and its gettin to the bearings. Go have a look.
John
trubluhq Offline
#11 Posted : Monday, 30 July 2007 8:16:18 PM(UTC)
trubluhq
#12 Posted : Tuesday, 31 July 2007 4:46:43 AM(UTC)
hi well a head job,now days????? is it a v6??
say for example a au falcon 6cyl one head, $500 to repair or exchange the head, add vrs kit coolant 8hrs labour,$1000...
is it a all alloy v6? and the heads have been off before?
how long ago? the alloy can
#13 Posted : Tuesday, 31 July 2007 4:46:43 AM(UTC)
how long ago? the alloy can go soft if it,s been to hot and the head bolts just sink into the head and not compression on the gasket,all over
you either have to do the job right$$$ or just chemi-weld and drive it into a car yard.
#14 Posted : Tuesday, 31 July 2007 5:10:44 AM(UTC)
Hi Guys,
It is a 2.2L 4 Cylinder :-)
When I checked the oil before it went in, it was a milky brown but I havent checked it since and cant check it now since it is dark and I dont have a flashlight.
Is their anything I can do just to stop the vibration so I can take it to one of those Cash for Cars places? Or even better, anyone from the ACT / NSW want to buy it?
- Adam
#15 Posted : Tuesday, 31 July 2007 5:10:44 AM(UTC)
Hi Guys,
When I checked the oil before it went in, it was a milky brown but I haven't checked it since and can't check it now since it is dark and I don't have a flashlight.
#16 Posted : Tuesday, 31 July 2007 9:18:13 AM(UTC)
Forgot to answer the other question, head gasket was replaced about 2 years ago.
What is chemi-weld?
#17 Posted : Tuesday, 31 July 2007 9:18:13 AM(UTC)
What is chemi-weld?
#18 Posted : Monday, 20 August 2007 3:27:40 AM(UTC)
Hey Guys,
Wondering if you can help me locate some engine sealant? Where can I get it from, I have been reading up on the net and it said it should be good for a few weeks to months until it can be fixed, just enough time for me to p!ss it off to a dealership.
Thanks Guys
#19 Posted : Monday, 20 August 2007 3:27:40 AM(UTC)
Hey Guys,
#20 Posted : Monday, 20 August 2007 5:50:27 AM(UTC)
g,day..
i recently done a head on a 2002 astra that broke a cambelt and bent all valves not including my 16 hours labour the total parts bill was about $3000.
as for chemi weld this stuff if used by directions is brilliant! I have used this on four
Guest (20)
This page was generated in 0.117 seconds.
