jayHK69 Offline
#1 Posted : Friday, 3 August 2007 3:52:58 AM(UTC)
jayHK69
does anyone know if there is a difference in the idler arm between manual & power steering in the hk t g range ?
thanks
#2 Posted : Friday, 3 August 2007 6:12:05 PM(UTC)
Hi jayHK69.
Yes & no.
The idler arm & support is the same for 6-cyl & 253/308 V8 for both manual & power steer. But the Chev V8s with power steering have different idlers to all others.
So, it depends on which engine you have.
jayHK69 Offline
#3 Posted : Saturday, 4 August 2007 12:08:03 AM(UTC)
jayHK69
thanks dr terry.
i`m confused now, i have hk prem with 307 manual steering, the drag link idler & support match exactly to one i compared from red 6cyl. i then compared this to a power set up i have to go into the car & it is visually exact.
does this
#4 Posted : Saturday, 4 August 2007 12:49:21 AM(UTC)
Hi jayHK69.
Yes, exactly. All the manual steer set-ups are the same, but the Chev power steer idler is unique.
The power steering set-up you have will be off a car that had a Holden motor.
Dr Terry.
jayHK69 Offline
#5 Posted : Saturday, 4 August 2007 4:25:09 AM(UTC)
jayHK69
so is there any way i can adapt what i have to use with the chev ?
#6 Posted : Saturday, 4 August 2007 5:40:48 PM(UTC)
Hi jayHK69.
I've never tried to do that, but the reason they're not the same, is sump clearance. The power steering ram is located in a different spot the clear the Chev sump. To achieve that, the ram bracket and idler support (which bolt together on t
#7 Posted : Saturday, 4 August 2007 5:40:48 PM(UTC)
Hi jayHK69.
Ive never tried to do that, but the reason theyre not the same, is sump clearance. The power steering ram is located in a different spot the clear the Chev sump. To achieve that, the ram bracket and idler support (which bolt together on the
#8 Posted : Saturday, 4 August 2007 8:42:50 PM(UTC)
Hi Terry
Does a monaro steering box work with just a manual steering setup and is there any issues I should be aware of?
thanks
#9 Posted : Saturday, 4 August 2007 8:45:18 PM(UTC)
Apologies for terry instead of meant to put Dr Terry, wife is typing and went to fast ha ha
Regards
Deb
#10 Posted : Sunday, 5 August 2007 3:43:21 AM(UTC)
Hi jay & deb.
There are 2 different steering boxes used in series HK/T/G. Theres the stock 20:1 box & the quick ratio (16:1) unit used in GTS Monaros (including GTS 327 & 350) & it is also fitted to all power steering cars. Not many people think of thi
#11 Posted : Sunday, 5 August 2007 3:43:21 AM(UTC)
Hi jay & deb.
There are 2 different steering boxes used in series HK/T/G. There's the stock 20:1 box & the quick ratio (16:1) unit used in GTS Monaros (including GTS 327 & 350) & it is also fitted to all power steering cars. Not many people think of th
#12 Posted : Sunday, 5 August 2007 9:40:27 PM(UTC)
Hi Dr Terry
Thank you for all your help and answering of questions regarding the power steering. I guess we will be now looking for chev power steering set up. I don't suppose you would know of any for sale?
Once again many thanks
jayson and deb
#13 Posted : Sunday, 5 August 2007 9:40:27 PM(UTC)
Hi Dr Terry
Thank you for all your help and answering of questions regarding the power steering. I guess we will be now looking for chev power steering set up. I dont suppose you would know of any for sale?
jayson and deb
Guest (6)
This page was generated in 0.091 seconds.
