#1 Posted : Friday, 3 August 2007 5:41:04 AM(UTC)
Hi i have a WB panelvan 202 column shift auto and would like to know whether i can change from column shift to t-bar auto without changing the gearbox itself just changing linkage setups. Any help would be much appreciated, thanks in advance.
basketcasebear Offline
#2 Posted : Friday, 3 August 2007 7:52:43 AM(UTC)
basketcasebear
i am not sure pvfan,,,but why would you want too?? i am trying to get rid of the damn thing, in the middle of the floor???? cluttering up everything, and collecting dirt and dust??
i wish i could put a column shift in?
ptpro
DOH!!!
#3 Posted : Saturday, 4 August 2007 12:02:19 AM(UTC)
Was thanked: 605 time(s) in 572 post(s)
You can. Copy the hole in the floor exactly off a floor shift HQ-WB and bolt in a factory RH shift T-bar. I used a UC Torana one with the integral indicator and put a vinyl boot around it so I didnt have to run a stupid console. But the UC shifter is a LH
#4 Posted : Saturday, 4 August 2007 12:02:19 AM(UTC)
You can. Copy the hole in the floor exactly off a floor shift HQ-WB and bolt in a factory RH shift T-bar. I used a UC Torana one with the integral indicator and put a vinyl boot around it so I didn't have to run a stupid console. But the UC shifter is a L
#5 Posted : Saturday, 4 August 2007 5:27:22 AM(UTC)
Just personal preferance i guess fallingbear. Thanks Byron Rich thats great info that will go to use. If anybody else has more info please dont hesitate to share, would b greatful.
#6 Posted : Saturday, 4 August 2007 5:27:22 AM(UTC)
Just personal preferance i guess fallingbear. Thanks Byron Rich that's great info that will go to use. If anybody else has more info please don't hesitate to share, would b greatful.
#7 Posted : Saturday, 4 August 2007 3:30:22 PM(UTC)
You will need:
T bar with lever and rod to box.
Console, I assume you willput in HJ to HZ
Wiring from T-bar to harness (two green wires, two purple wires, one grey.
As Byron has pointed out the T-bat shift can be left or right and may need the adjus
#8 Posted : Friday, 10 August 2007 3:29:45 AM(UTC)
Thanks warren for that info will be very helpful.
#9 Posted : Sunday, 19 August 2007 11:27:40 PM(UTC)
dont know much about shifters but instead of putting a standard t-bar shifter in, could i put a B&M or Hurst shifter in to replace the column shift.
#10 Posted : Sunday, 19 August 2007 11:27:40 PM(UTC)
don't know much about shifters but instead of putting a standard t-bar shifter in, could i put a B&M or Hurst shifter in to replace the column shift.
Guest (9)
