#1 Posted : Sunday, 5 August 2007 7:36:28 PM(UTC)
Iv got a HG Premier with a cooling problem...It just doesnt like traffic. the first hint of idelling for a long time, the bloody thing just starts to cook. I've been led to believe this is a common problem as the radiator is too small for this engine. Im looking for a replacement radiator, but dont know what to rip one out of. I dont want the conversion to be too dificult. Does any one know what will fit in with minimum fuss? Thanks.
81837 Offline
#2 Posted : Sunday, 5 August 2007 8:52:11 PM(UTC)
81837
Which engine?
#3 Posted : Monday, 6 August 2007 12:16:46 AM(UTC)
Oh yeah, that'l prob help! Its a 253
#4 Posted : Monday, 6 August 2007 12:16:46 AM(UTC)
Oh yeah, thatl prob help! Its a 253
#5 Posted : Monday, 6 August 2007 2:59:41 AM(UTC)
Get the cooling system flushed first.
hz dude Offline
#6 Posted : Monday, 6 August 2007 4:22:06 AM(UTC)
hz dude
Is it a standard core or a three core radiator?
if its a standard change to the 3 core
if its the 3 core a flush like BYRON said would help.
maybe change the thermostat to a lower opening temp.
means more flow might help
it's beer o'clock
hz dude Offline
#7 Posted : Monday, 6 August 2007 4:22:06 AM(UTC)
hz dude
its beer oclock
hazzard county Offline
#8 Posted : Tuesday, 7 August 2007 5:33:42 AM(UTC)
hazzard county
car dont normally over heat unless there is a problem within the cooling system itself or it has been modified in some way a mate of mine has a 12sec 308 prem worked off its face & done the standard thing big radiator electric water pump & thermo fans & a
adam PERTH Offline
#9 Posted : Tuesday, 7 August 2007 8:26:31 AM(UTC)
adam PERTH
HG Prem.
Whether or not your want to fork out the $70 to get your rad serviced (top removed and cleaned)
Put a cup of laundery detergent in your radiator first, run until warm, then dump via bottom rad hose.
repeat 3-4 times.
This will soften the wat
