Holden One Offline
#1 Posted : Monday, 6 August 2007 6:09:13 AM(UTC)
Holden One
Guys,
Just now in the process of restoring my SLR 6 Cylinder (LX) and wanting your opinions.
As it is all original i will be spraying it the same colour.
My question is as it is a 6, i am thinking of replacing this with a V8 (308).
In terms of resale value down the track 3-5 years, would i be better keeping the 6 in it or replace with the V8.
Although my heart says goes with the V8, my brains saying to keep the 6 cylinder.
What are your thoughts?????
Jamie
adam PERTH Offline
#2 Posted : Monday, 6 August 2007 6:18:20 AM(UTC)
adam PERTH
whatever you do. dont get rid of that original motor with those casting #s, and keep your banjo diff.
dont modify / cut holes in Console / Dash either.
keep it 6, but everyone is different.!
Being a Bogan is finally paying dividends.
adam PERTH Offline
#3 Posted : Monday, 6 August 2007 6:18:20 AM(UTC)
adam PERTH
whatever you do. don't get rid of that original motor with those casting #'s, and keep your banjo diff.
don't modify / cut holes in Console / Dash either.
#4 Posted : Monday, 6 August 2007 6:35:44 AM(UTC)
I sort of agree with Adam. Restore it body wise and interior to original. Basically everything as factory. But put what engine in it you like. If you use a 308, simply put a V8 Aussie 4-speed in it. The 6cyl and V8 boxes fit in exactly the same place, and
Ado Offline
#5 Posted : Tuesday, 7 August 2007 4:57:48 AM(UTC)
Ado
I would be more than happy to own an SL/R 6 cylinder. When a car becomes a classic I think it doesnt really matter how fast it is. I get a lot of satisfaction out of cars that you actually have to drive rather than just sit there and try and look like it
Ado Offline
#6 Posted : Tuesday, 7 August 2007 4:57:48 AM(UTC)
Ado
I would be more than happy to own an SL/R 6 cylinder. When a car becomes a classic I think it doesn't really matter how fast it is. I get a lot of satisfaction out of cars that you actually have to drive rather than just sit there and try and look like it
#7 Posted : Wednesday, 8 August 2007 10:35:24 AM(UTC)
I agree with the others. Don't do any alterations that cannot be easily changed. Any parts you pull off, no matter how tiny, put in a box in the garage and label them so you remember. Anything you pull off will probably not be available in a few years.
T
#8 Posted : Wednesday, 8 August 2007 10:35:24 AM(UTC)
I agree with the others. Dont do any alterations that cannot be easily changed. Any parts you pull off, no matter how tiny, put in a box in the garage and label them so you remember. Anything you pull off will probably not be available in a few years.
To
ozjason Offline
#9 Posted : Wednesday, 8 August 2007 11:47:56 PM(UTC)
ozjason
Hi Jamie,
I have an LH G-Pak, which essentially is an SLR 3300, when it comes to the running gear. (202, M20 box, SLR diff ratios.)
I did a ring in the original engine after 220,000km a few years ago and had a mild rebuild done on the same engine.
#10 Posted : Wednesday, 8 August 2007 11:52:13 PM(UTC)
What is a H series? HR? HD? HT? what R you on about???
Holden One Offline
#11 Posted : Thursday, 9 August 2007 4:16:25 AM(UTC)
Holden One
Hey Guys,
You have pursuaded my thoughts and to keep the old 6 cylinder. Whilst it is out of the car, might give it a set of rings and bearings as it runs good as it is now.
Thanks everyone for your input......
Originality is the way to go.
Ch
