Holden One Offline
#1 Posted : Monday, 6 August 2007 6:09:13 AM(UTC)
Holden One
Guys,
Just now in the process of restoring my SLR 6 Cylinder (LX) and wanting your opinions.
As it is all original i will be spraying it the same colour.
My question is as it is a 6, i am thinking of replacing this with a V8 (308).
In terms of resale value down the track 3-5 years, would i be better keeping the 6 in it or replace with the V8.
Although my heart says goes with the V8, my brains saying to keep the 6 cylinder.
What are your thoughts?????
Jamie
adam PERTH Offline
#2 Posted : Monday, 6 August 2007 6:18:20 AM(UTC)
adam PERTH
whatever you do. dont get rid of that original motor with those casting #s, and keep your banjo diff.
dont modify / cut holes in Console / Dash either.
keep it 6, but everyone is different.!
Being a Bogan is finally paying dividends.
adam PERTH Offline
#3 Posted : Monday, 6 August 2007 6:18:20 AM(UTC)
adam PERTH
whatever you do. don't get rid of that original motor with those casting #'s, and keep your banjo diff.
don't modify / cut holes in Console / Dash either.
#4 Posted : Monday, 6 August 2007 6:35:44 AM(UTC)
Was thanked: 605 time(s) in 572 post(s)
I sort of agree with Adam. Restore it body wise and interior to original. Basically everything as factory. But put what engine in it you like. If you use a 308, simply put a V8 Aussie 4-speed in it. The 6cyl and V8 boxes fit in exactly the same place, and
Ado Offline
#5 Posted : Tuesday, 7 August 2007 4:57:48 AM(UTC)
Ado
I would be more than happy to own an SL/R 6 cylinder. When a car becomes a classic I think it doesnt really matter how fast it is. I get a lot of satisfaction out of cars that you actually have to drive rather than just sit there and try and look like it
Ado Offline
#6 Posted : Tuesday, 7 August 2007 4:57:48 AM(UTC)
Ado
I would be more than happy to own an SL/R 6 cylinder. When a car becomes a classic I think it doesn't really matter how fast it is. I get a lot of satisfaction out of cars that you actually have to drive rather than just sit there and try and look like it
#7 Posted : Wednesday, 8 August 2007 10:35:24 AM(UTC)
I agree with the others. Don't do any alterations that cannot be easily changed. Any parts you pull off, no matter how tiny, put in a box in the garage and label them so you remember. Anything you pull off will probably not be available in a few years.
T
#8 Posted : Wednesday, 8 August 2007 10:35:24 AM(UTC)
I agree with the others. Dont do any alterations that cannot be easily changed. Any parts you pull off, no matter how tiny, put in a box in the garage and label them so you remember. Anything you pull off will probably not be available in a few years.
To
ozjason Offline
#9 Posted : Wednesday, 8 August 2007 11:47:56 PM(UTC)
ozjason
Hi Jamie,
I have an LH G-Pak, which essentially is an SLR 3300, when it comes to the running gear. (202, M20 box, SLR diff ratios.)
I did a ring in the original engine after 220,000km a few years ago and had a mild rebuild done on the same engine.
#10 Posted : Wednesday, 8 August 2007 11:52:13 PM(UTC)
What is a H series? HR? HD? HT? what R you on about???
Holden One Offline
#11 Posted : Thursday, 9 August 2007 4:16:25 AM(UTC)
Holden One
Hey Guys,
You have pursuaded my thoughts and to keep the old 6 cylinder. Whilst it is out of the car, might give it a set of rings and bearings as it runs good as it is now.
Thanks everyone for your input......
Originality is the way to go.
Ch
This page was generated in 0.066 seconds.
