#1 Posted : Wednesday, 8 August 2007 5:27:02 AM(UTC)
Ok I am going to have a crack at doing a mild rebuild on my red 308 in my ute. Just wondering if anyone has done a rebuild and can offer any advice. It is a red 308 edelbrock performer manifold heatseeker cam, 650 holley, double valve springs everything else is standard just want to fix her up so she is a good streeter nothing over the top I am going to keep the cam and stuff like that as it is quite new and a good cam. What has inspired this is the engine has never ran excellent and tends to overheat quite alot the engine sat for well over a year, without being started and this is when the probs started with the overheating. A friend of mine has told me that the water jackets could have alot of crap built up inside them Any advice from anyone would be good thanks
#2 Posted : Wednesday, 8 August 2007 6:46:46 AM(UTC)
New pistons, rings, bearings, balance. Hot tank block and new cam bearings and paint. Head service. Leave standard size valves. Extractors. HEI dizzy. New cast iron oil pump. Throw the Holley away and get a Quadrajet set up properly. Dont mix up the lifte
#3 Posted : Wednesday, 8 August 2007 6:46:46 AM(UTC)
New pistons, rings, bearings, balance. Hot tank block and new cam bearings and paint. Head service. Leave standard size valves. Extractors. HEI dizzy. New cast iron oil pump. Throw the Holley away and get a Quadrajet set up properly. Don't mix up the lift
#4 Posted : Wednesday, 8 August 2007 9:24:34 AM(UTC)
good luck building your engine.
adam PERTH Offline
#5 Posted : Wednesday, 8 August 2007 9:18:15 PM(UTC)
adam PERTH
replace timing chain also
have a good look at cam, GM V8 ones are normally only good for 100,000 km.
Flick holley, get a AC delco reco Rochchester quadrajet from Eagle auto spares.
probably go with a STD oil pump, not HV oil pump for mild rebuild.
( H
#6 Posted : Thursday, 9 August 2007 2:20:02 AM(UTC)
Is there any truth to the rumour that only Homersexuals drive two-fifty-three powered cars? just wondering
HS
boom Offline
#7 Posted : Thursday, 9 August 2007 4:14:17 AM(UTC)
boom
can one of the moderators delete this person's posts please
If it doesn’t burn fossil fuels, it’s not a sport.
boom Offline
#8 Posted : Thursday, 9 August 2007 4:14:17 AM(UTC)
boom
can one of the moderators delete this persons posts please
#9 Posted : Thursday, 9 August 2007 4:17:30 AM(UTC)
Raw-Nerve 253 Homersexual Dunnydoor owner
adam PERTH Offline
#10 Posted : Thursday, 9 August 2007 5:39:28 AM(UTC)
adam PERTH
he obviously drives a ford.
i mean, the absolute best they can offer is the XY phase 3.
............ and it couldnt even beat the humble 202 at bathurst.
Being a Bogan is finally paying dividends.
adam PERTH Offline
#11 Posted : Thursday, 9 August 2007 5:39:28 AM(UTC)
adam PERTH
............ and it couldn't even beat the humble 202 at bathurst.
#12 Posted : Saturday, 11 August 2007 1:32:34 AM(UTC)
ignore ignore and ignore
Guest (12)
