jayHK69 Offline
#1 Posted : Saturday, 11 August 2007 10:50:52 AM(UTC)
jayHK69
just want to know if gasless mig is any good for rust/panel repairs ?
or would i be better off with the gas/gasless type ?
would a 100 amp model be any good for this type of work ?
#2 Posted : Saturday, 11 August 2007 4:52:16 PM(UTC)
Generally speaking yes, a 100 amp gas welder is capable of welding aprox steel 3.5mm thick. The only thing to watch is the dutty cycles on those cheapies. You may spend more time smoking durries and drinking beer - than actually welding.
#3 Posted : Monday, 13 August 2007 1:16:50 AM(UTC)
gasless is no good for thin material it burns too hot. its great for you carport or the fence or shed you want to build but no good for thin material.
100amp will be heaps! for tin work.
jason
peter_flane Offline
#4 Posted : Monday, 13 August 2007 5:39:13 AM(UTC)
peter_flane
Gasless is for garden gates.
If you get a super cheap welder you will end up with a super cheap job on a super cheap car.
Spending about $700 on a decent 150A GMAW (Gas Metal Arc Welder) or commonly called MIG, and hiring a gas bottle for about $100
vintageholden Offline
#5 Posted : Monday, 13 August 2007 8:45:16 AM(UTC)
vintageholden
same argument as last time
i have gasless mig and do all my rust repairs with it
1mm and less i have 120 amp and it works great
welds arnt the best looking but for rust repairs you grind the welds down any way
arse_wipe Offline
#6 Posted : Thursday, 16 August 2007 4:55:42 PM(UTC)
arse_wipe
I have a CIG gasless, has done everything that I have thrown at it yet, gas is better though,,,,
John
Silence is non-committal
John
#7 Posted : Friday, 17 August 2007 12:42:17 AM(UTC)
vintageholden
gas is much better
but if gassless is all you have its fine
Dicko Offline
#8 Posted : Friday, 17 August 2007 9:41:53 AM(UTC)
Dicko
My brother used our Cig gasless unit to weld a new lower section onto a HG front gaurd last weekend and he got a very good result. You do need good wire though.
"Inteligence is knowing the
"Inteligence is knowing the extent of your opponents stupidity."
keithholden Offline
#9 Posted : Sunday, 19 August 2007 4:02:43 AM(UTC)
keithholden
Ive used my gasless welder now for many years in fact now they are so cheap compaired to what I paid. I use 0.9mm wire with flux core. Just go slow do a spot here and a gap then a spot then a gap.. if you burn a hole you just do a small zap wait a sec th
Edited by user Sunday, 19 August 2007 4:04:59 AM(UTC)  | Reason: Not specified
peter_flane Offline
#10 Posted : Sunday, 19 August 2007 5:00:09 AM(UTC)
peter_flane
Have any of you guys with gasless setups tried using gas? You may be very surprised at how much your skill/ workmanship/ weld profile will be so much easier or better. I am saying this in a positive way.
#11 Posted : Tuesday, 21 August 2007 7:14:28 AM(UTC)
i use gaseless mig all time to weld car panels
good quality wire is a must as diff brands weld differently
#12 Posted : Tuesday, 21 August 2007 10:42:03 PM(UTC)
What is a good quality brand of wire to use? I use CIG stuff & my gasless welds are nothing short of fugly.
It shi ts me to tears when the media & sta
Edited by user Tuesday, 21 August 2007 11:55:54 PM(UTC)  | Reason: Not specified
arse_wipe Offline
#13 Posted : Tuesday, 21 August 2007 11:31:23 PM(UTC)
arse_wipe
I use the CIG stuff on my CIG, I have no drama's, a little messy with thin metal but have done stainless intercooling piping and all, with exceptional results,,,,
John
John
arse_wipe Offline
#14 Posted : Tuesday, 21 August 2007 11:31:23 PM(UTC)
arse_wipe
I use the CIG stuff on my CIG, I have no dramas, a little messy with thin metal but have done stainless intercooling piping and all, with exceptional results,,,,
John
John
peter_flane Offline
#15 Posted : Wednesday, 22 August 2007 5:56:10 AM(UTC)
peter_flane
"my gasless welds are nothing short of fugly"
"a little messy with thin metal"
Question was "Have you guys tried gas welding?"
arse_wipe Offline
#16 Posted : Wednesday, 22 August 2007 7:13:23 AM(UTC)
arse_wipe
err, yes, did a little bit at tech and quite a lot the years I worked at Lincoln Electric,,,,
John
John
#17 Posted : Wednesday, 22 August 2007 7:42:53 PM(UTC)
Edited by user Wednesday, 22 August 2007 11:43:11 PM(UTC)  | Reason: Not specified
