253
#1 Posted : Tuesday, 14 August 2007 1:51:35 AM(UTC)
its no doubt an old question how do more grunt from a 253 cheers ps it will be on duel fuel i dont want to go 308
boom Offline
#2 Posted : Tuesday, 14 August 2007 3:03:57 AM(UTC)
boom
turbo
If it doesn’t burn fossil fuels, it’s not a sport.
trubluhq Offline
#3 Posted : Wednesday, 15 August 2007 1:12:08 AM(UTC)
trubluhq
hmm...warm cam, electonic ignition. put on LPG heads...quad 308 manifold and Quaddie. cold air injection, prob suitable pistons to raise the compression ratio, a known good and tested crank too. I think 2.5 inch singles are the go..or balanced twins with
JBM Offline
#4 Posted : Wednesday, 15 August 2007 1:32:37 AM(UTC)
JBM
Early 253s had dome top pistons, are sure way to increase the compression. This way you dont have to shave the head or block. New valve guides would also help the top end lubrication problems with ULP. You can put big valve or VN heads on if you want to r
#5 Posted : Wednesday, 15 August 2007 6:47:41 AM(UTC)
Other way round. Late red 253's had the high comp pistons. Early ones were flat top.
#6 Posted : Wednesday, 15 August 2007 6:47:41 AM(UTC)
Other way round. Late red 253s had the high comp pistons. Early ones were flat top.
#7 Posted : Wednesday, 15 August 2007 7:29:23 AM(UTC)
Hi John,
For all the suggestions getting more grunt from a 253... Why even bother..!!
The price of a good running 308 is so cheap these days that it would cost a lot more to start dicking around with a wantabe V8 like the 253...
Simply buy a seco
maccaq Offline
#8 Posted : Saturday, 18 August 2007 6:38:36 AM(UTC)
maccaq
I have the same problem. I want to keep my 253 HQ Munro matching no.s so I dont want to flick it in favour of a 308. Any other suggestions?
maccaq Offline
#9 Posted : Saturday, 18 August 2007 6:38:36 AM(UTC)
maccaq
I have the same problem. I want to keep my 253 HQ Munro matching no.'s so I don't want to flick it in favour of a 308. Any other suggestions?
musksell Offline
#10 Posted : Saturday, 18 August 2007 7:12:32 AM(UTC)
musksell
Theres lots of ways.....I think really it's all about how much money you want to spend.
1. put 5 litre VN heads and injection on it.Wait another 3 years for LPG injection to be half the price it is now ($4000).
2. You want to run LPG....so put 4 b
musksell Offline
#11 Posted : Saturday, 18 August 2007 7:12:32 AM(UTC)
musksell
Theres lots of ways.....I think really its all about how much money you want to spend.
2. You want to run LPG....so put 4 ba
adam PERTH Offline
#12 Posted : Saturday, 18 August 2007 12:02:10 PM(UTC)
adam PERTH
i am in a simular situation to maccaq,
have a few factory L32 cars that i with to retain matching numbers throughout.
When it comes time for engine rebuild, i will look hard at going 292.
i understand it uses a 307 slug,(3.85 ") , what else is involved
maccaq Offline
#13 Posted : Saturday, 18 August 2007 10:42:57 PM(UTC)
maccaq
So you mean you bore out the 253 to 292 with oversize pistons etc.?
musksell Offline
#14 Posted : Sunday, 19 August 2007 5:27:09 AM(UTC)
musksell
I havn't heard of boring them out to 292.....but I could easily be wrong.
I meant stroking them out....which ends up being 88mm stroke and about 92mm for the 253 std bore.....this is a lot closer to the "ideal" square bore and stroke configuration.
R
musksell Offline
#15 Posted : Sunday, 19 August 2007 5:27:09 AM(UTC)
musksell
I havnt heard of boring them out to 292.....but I could easily be wrong.
Re
adam PERTH Offline
#16 Posted : Sunday, 19 August 2007 5:41:16 AM(UTC)
adam PERTH
i have heard of 292 - yes bored out 253's
3.85 inch bore...?
like to hear from others???
A1 Bogan.
adam PERTH Offline
#17 Posted : Sunday, 19 August 2007 5:41:16 AM(UTC)
adam PERTH
i have heard of 292 - yes bored out 253s
3.85 inch bore...?
A1 Bogan.
keithholden Offline
#18 Posted : Sunday, 19 August 2007 5:42:32 AM(UTC)
keithholden
I dont think you have to go overboard all you need in my opinion is a cam and extractors.. Cam is the cheapest way to increase horsepower.. You dont need to go to extravagant..
Simple is best. Cause im kind of simple.. Now dont answer that lol
If its
antoni Offline
#19 Posted : Sunday, 19 August 2007 8:53:30 AM(UTC)
antoni
Hi all 253s I were as big as 290 used std 305 chev pistions
masterstroke did the cranks sj chev 283 rods.
VN heads vales to wide a part.
VN rods to heavy.
tony
