tony_vc Offline
#1 Posted : Tuesday, 14 August 2007 4:25:04 AM(UTC)
tony_vc
hey guys
im tony , 16
currently doing up my vc commodore
i would like heaps more power outa it
and would like to no wat i can do to do that
and ive been told that ive got a 10bolt diff??
id like to rip 2 nice lines down the road..wat diffs would fit
thanx guys
tony_vc Offline
#2 Posted : Tuesday, 14 August 2007 4:26:50 AM(UTC)
tony_vc
oh yer and its a 202 blue motor
got exteactors..thats all i know of ahah
boom Offline
#3 Posted : Tuesday, 14 August 2007 5:01:13 AM(UTC)
boom
10 bolt is good. whack on a black efi head and the efi gear off a VK.
Shave the head etc raise compression. and advance the timing a little. that's a start.
If it doesn’t burn fossil fuels, it’s not a sport.
boom Offline
#4 Posted : Tuesday, 14 August 2007 5:01:13 AM(UTC)
boom
Shave the head etc raise compression. and advance the timing a little. thats a start.
adam PERTH Offline
#5 Posted : Tuesday, 14 August 2007 6:12:00 AM(UTC)
adam PERTH
Hi tony.
good to see you have a great goal.
2 black lines.!
10 Bolt sailsbury's into early commodores aren't cheap to replace.
so,
before you cut up, change your oil in motor box and diff.
if auto, get a trans cooler, 2nd hand ok (clean first)
adam PERTH Offline
#6 Posted : Tuesday, 14 August 2007 6:12:00 AM(UTC)
adam PERTH
Hi tony.
2 black lines.!
10 Bolt sailsburys into early commodores arent cheap to replace.
so,
yo
tony_vc Offline
#7 Posted : Wednesday, 15 August 2007 1:12:06 AM(UTC)
tony_vc
oh k thanx..umm ive changed all the oils but just not the diff 1..
umm
i wanna put pictures up but i dont know how 2..im kinda new to this forum stuff
are trans coolers easy to fit?
it is auto..3spd..
how do i no if its lsd or not cause som
Edited by user Wednesday, 15 August 2007 1:16:11 AM(UTC)  | Reason: Not specified
tony_vc Offline
#8 Posted : Wednesday, 15 August 2007 1:22:42 AM(UTC)
tony_vc
Edited by user Wednesday, 15 August 2007 4:19:48 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#9 Posted : Wednesday, 15 August 2007 5:22:06 AM(UTC)
adam PERTH
chances are , you have a single spinner.
jack one wheel up, can you turn it by hand?
yes = single spinner
No = something else, perhaps LSD or MIG.
if you cant turn
Put a torque wrench on a wheel nut, see how much pound it takes to turn.
new, the L
adam PERTH Offline
#10 Posted : Wednesday, 15 August 2007 5:22:06 AM(UTC)
adam PERTH
if you can't turn
new, the
tony_vc Offline
#11 Posted : Wednesday, 15 August 2007 5:49:36 AM(UTC)
tony_vc
oh k sweet
2day i was in my back yard and i got kinda bogged...so i gave it some....and both spun...i dont no if thats cause i was on dirt but yer both spun..weird haha
im stumpd
know of any air filters ..the 1s where u can see the filter around
adam PERTH Offline
#12 Posted : Wednesday, 15 August 2007 7:56:27 AM(UTC)
adam PERTH
ok,
look at the carb again, stromberg or Strasburg?
Some varijets were made in strasberg.
not sure on air filter aftermarket for varijet.
try a speed shop.
Being a Bogan is finally paying dividends.
Guest (6)
