BAD WB Offline
#1 Posted : Tuesday, 14 August 2007 5:38:47 AM(UTC)
BAD WB
Gday All
On my WB ute i want to change it over to a statesman front end. Just wandering if i only have to change over the lights and the grill or if i have to change over the nose cone and the bumper as well. Any info would be good.
Cheers BAD WB
vintageholden Offline
#2 Posted : Wednesday, 15 August 2007 12:17:54 AM(UTC)
vintageholden
change the whole lot and sell yours to me
adam PERTH Offline
#3 Posted : Wednesday, 15 August 2007 5:46:53 AM(UTC)
adam PERTH
Kieth, i have a good series 2 WB kingswood front clip on the farm, even the plastic bumper bar inner or what ever you call it is still good! rust free.
call me if you want it.
Being a Bogan is finally paying dividends.
adam PERTH Offline
#4 Posted : Wednesday, 15 August 2007 5:53:19 AM(UTC)
adam PERTH
BAD WB.
CHange your whole clip if possible, faster and easier.(30 min off, 30 min on)
paint it when its off,?
plug your harness in when you are done!
otherwise, you will have to delete that little metal piece to allow for the longer lights.
Not sur
#5 Posted : Wednesday, 15 August 2007 6:49:07 AM(UTC)
Differences are nose, radiator support and lights. Plus harness of course. Bumbers are interchangeable but Statesman has the rubber.
If we all had the same (good) taste, who would buy all the For
Rhys Offline
#6 Posted : Wednesday, 15 August 2007 9:44:23 AM(UTC)
Rhys
adam PERTH - What is the difference between series I WB Kingswood and series II WB Kingswood front clips? I thought they were identical from 1980-1984.
adam PERTH Offline
#7 Posted : Wednesday, 15 August 2007 10:07:09 AM(UTC)
adam PERTH
Series 1 is the round headlight with steel grille - not real popular.
Didn't last long into 1980 before they changed to Square headlight, series 11. anyone know when?
there were also series 1 and 2 WB Statesmans
adam PERTH Offline
#8 Posted : Wednesday, 15 August 2007 10:07:09 AM(UTC)
adam PERTH
Didnt last long into 1980 before they changed to Square headlight, series 11. anyone know when?
#9 Posted : Wednesday, 15 August 2007 4:23:41 PM(UTC)
Round headlight was just the base model (HOLDEN) introduced in April 1980. The square headlight was the KINGSWOOD ute also released in April 1980. The square headlight became standard on HOLDEN ute/van in August 1980 and on the tonner in April 1981. They
