keithholden Offline
#1 Posted : Wednesday, 15 August 2007 3:23:35 AM(UTC)
keithholden
HI I have an HQ ive just put a 350chev into.
I would like to keep every thing under the bonnet and so today I brought a air cleaner called a low slung one but it was to big in width and hit on my HEI dizzy cap
My inlet manafold is what id call a semi high rise .. the bonnet closes over my carb but I cant tell how much space is left between it and the bonnet..
Any suggestions as to what air cleaner to buy. Or do I have to cut a hole in the bonnet?
Cheers for any advice
adam PERTH Offline
#2 Posted : Wednesday, 15 August 2007 5:39:33 AM(UTC)
adam PERTH
Cut your bonnet ribs out first
semi hi rise???
which one?
Weiand xcellerator / Eldelbrock Perf RPM + other stage 3 equivalents, you should be able to get away with 2" air cleaner when you cut the ribs out.
If you have Victor JNR, or simular, you wil
keithholden Offline
#3 Posted : Wednesday, 15 August 2007 6:27:24 AM(UTC)
keithholden
Hi I got a 14inch wide air cleaner today and its called a low slung one it hit my dizzy hei.. I just had a look and its a Weiand 7508 if that means any thing to you?
jabba Offline
#4 Posted : Thursday, 16 August 2007 4:48:06 PM(UTC)
jabba
Had similar issues myself. I ended up tossing the "drop base" air filter (as it was taking about 5 hp out of the engine according to dyno). Ended up with a triangular "RamFlo" filter, which is a base plate, with a mesh covered foam element above. Worke
keithholden Offline
#5 Posted : Sunday, 19 August 2007 3:53:13 AM(UTC)
keithholden
Hi turns out the low slung air cleaner did fit I just had to put it on in the day time lol.. It hit the leads and the fuel line but after some moving things to the side and down it now fits with a 2 inch air cleaner.
Phew one more thing sorted..
If it
