spoynts Offline
#1 Posted : Wednesday, 15 August 2007 4:15:08 AM(UTC)
spoynts
ivr got a 1964 xm faclon with drum brakes all round.... what i was looking for info on converting to disc front end. Which model stub axle is required and how much effort is required to do the changeover? After doing this does it need to be engeneered or is that only for the engine work ?
thanks steve
#2 Posted : Thursday, 16 August 2007 12:09:57 AM(UTC)
Well there is a common sleeve kit so that you can fit the whole brake assembly including stub axles from any XR-XG Falcon. If you use this kit though you will need five stud front wheels but still have four stud up the back.
Sigma's Corona's & Nissa
camlj Offline
#3 Posted : Thursday, 16 August 2007 6:08:02 AM(UTC)
camlj
hey mate. i've got a four stud disc front end on my xp donor car in my backyard. not sure of the condition but will have a closer look if you're genuinely interested. i assume it will pretty much bolt straight in to your xm. not sure how much its worth bu
spoynts Offline
#4 Posted : Thursday, 16 August 2007 3:52:28 PM(UTC)
spoynts
thanks Jim for the info. Camlj, where about are you located? would it be posible for me to check it out?
thanks steve
[email protected]
#5 Posted : Saturday, 18 August 2007 3:09:55 AM(UTC)
hey mate. i'm in sydney. near the dural area. yeh you can check it out whenever. i'm away this weekend though so maybe send me an email and we can arrange something late. [email protected]
thanks steve.
#6 Posted : Tuesday, 21 August 2007 8:07:09 AM(UTC)
Easiest way to convert is to use XF Falcon stub axles/disc & calipers, only thing extra needed to bolt these up is tapered sleeves for the outer tie rod ends, I can supply these for $50pr. These can be picked up at any wreckers cheaply and have less wear
Dmax Offline
#7 Posted : Tuesday, 21 August 2007 9:28:30 PM(UTC)
Dmax
As Deon says, go the XF stub axle mate, nice modern brake set up, and the parts are readily available.
648hp Tunnel Rammed 351, It does not get any better
Guest (6)
This page was generated in 0.141 seconds.
