hz dude Offline
#1 Posted : Thursday, 16 August 2007 7:22:19 AM(UTC)
hz dude
where the hell is the engine number on a VN series 1.
just on a rebuild preping the engine for the rebuild
didnt see the engine number. so got out the trusty
wire brush on the drill still cant find it
just puzzeled. thanx dudes
its beer o'clock
JBM Offline
#2 Posted : Thursday, 16 August 2007 7:50:56 AM(UTC)
JBM
V6 or V8.
The V8 number is on the passenger side of the block below No2 spark plug.
V6?
James
hz dude Offline
#3 Posted : Thursday, 16 August 2007 8:08:15 AM(UTC)
hz dude
sorry dude its a V6 got 2 to look at still
cant find it . god damd VN peice of ____
fill in the gaps
thanx dudes
its beer oclock
hz dude Offline
#4 Posted : Thursday, 16 August 2007 8:08:15 AM(UTC)
hz dude
fill in the gaps
thanx dudes
it's beer o'clock
JBM Offline
#5 Posted : Thursday, 16 August 2007 9:06:15 AM(UTC)
JBM
For the V6 its in a similar position, underneath the coil packs, on the side of the block. Info from the VR-VS Ellery book.
James
#6 Posted : Thursday, 16 August 2007 9:15:01 AM(UTC)
Front face of the block, where it's flat, below the level of the water pump, on the passenger side.
It's a biatch of a spot to get a good look at.
A lot of people ai
#7 Posted : Thursday, 16 August 2007 9:15:01 AM(UTC)
Front face of the block, where its flat, below the level of the water pump, on the passenger side.
Its a biatch of a spot to get a good look at.
A lot of people aim
hz dude Offline
#8 Posted : Friday, 17 August 2007 6:52:19 AM(UTC)
hz dude
thanx dudes . the motors on a stand so not so hard to see
but when its back in the car what a pain in the butt
VH 100xxxx eng # dont spose it can be out of any thing eles
with the thomostat at the rear. makes sense that it can only
be out of series 1.
#9 Posted : Friday, 17 August 2007 9:49:40 AM(UTC)
Yep, definately an early VN motor by the number and the thermostat location.
#10 Posted : Friday, 17 August 2007 8:33:48 PM(UTC)
Hi Guys.
I know I sound a little pedantic on this one, but about 50% of Series 2 VNs also use the early type motor. I so often hear the comment 'it doesn't have a VP type motor so it is a Series 1'.
This is not correct. The Series 2 VN was introdu
#11 Posted : Friday, 17 August 2007 8:33:48 PM(UTC)
Hi Guys.
I know I sound a little pedantic on this one, but about 50% of Series 2 VNs also use the early type motor. I so often hear the comment it doesnt have a VP type motor so it is a Series 1.
This is not correct. The Series 2 VN was introduced
#12 Posted : Saturday, 18 August 2007 1:48:31 AM(UTC)
hi dude whats in a rebuild of a v6 is it as straight foward as any other engine its just that i have asked the question before and never got an answer i find these engines complete in the local scrap yard i could get a couple for next to nothing cheers
#13 Posted : Saturday, 18 August 2007 3:00:34 AM(UTC)
Hi john.
If you can get complete 'runners' cheap, go for it.
These days it costs a fair bit to do a proper rebuild. Assuming the heads get overhauled, it gets bored with new pistons & rings & the crank needs machining you can spend $1500 to $2000 j
#14 Posted : Saturday, 18 August 2007 3:00:34 AM(UTC)
Hi john.
If you can get complete runners cheap, go for it.
These days it costs a fair bit to do a proper rebuild. Assuming the heads get overhauled, it gets bored with new pistons & rings & the crank needs machining you can spend $1500 to $2000 jus
hz dude Offline
#15 Posted : Saturday, 18 August 2007 5:17:37 AM(UTC)
hz dude
its about $1000 .down here east of melbourne.
thats the bottom end and gaskets.
thats a reboer new pistons,rings,shells,mains
big ends,cam shells and i can get a bloke to check
the heads over for about $80 for both (no parts)
and then your time not
#16 Posted : Saturday, 18 August 2007 7:22:06 AM(UTC)
Hi hz dude.
As I said, if the heads need a full overhaul & the crank needs grinding, it will cost $1500 +.
