basketcasebear Offline
#1 Posted : Saturday, 18 August 2007 8:56:43 AM(UTC)
basketcasebear
just measured the rear axle width on this transit, and it is 1500mm or 59inchs, so i am wondering what a wide vehikle axle is like say a fairlane or statesman, is? maybe i can put a normal wider axle in the transit, to get higher ratio diff?
any thoughts greatly appreciated.
ptpro
DOH!!!
#2 Posted : Saturday, 18 August 2007 5:52:52 PM(UTC)
Hi FB.
Check your other post for more about diff swaps, but 1500mm isn't very wide, in fact that's about the same as early (VB to VL) Commodores. Also Fairlanes & Statesmans rear axles are no different to the Falcon or Holden that they're based on. Thi
#3 Posted : Saturday, 18 August 2007 5:52:52 PM(UTC)
Hi FB.
Check your other post for more about diff swaps, but 1500mm isnt very wide, in fact thats about the same as early (VB to VL) Commodores. Also Fairlanes & Statesmans rear axles are no different to the Falcon or Holden that theyre based on. This i
