#1 Posted : Sunday, 19 August 2007 2:29:45 AM(UTC)
Hi can any one help having trouble getting the pulley of the shaft on my v8 vp calais
keithholden Offline
#2 Posted : Sunday, 19 August 2007 4:22:24 AM(UTC)
keithholden
I use 2 really large screwdrivers and put them one on each side behind the pulley and pull forward on one then the other .. On one car I even managed to get the flat part of a spade behind the pulley and screw driver on the other.Ive even tried to use th
#3 Posted : Sunday, 19 August 2007 4:42:31 AM(UTC)
do I have to take the hex bolt out first or does that come of with the pulley or is that part of the shaft thanks for your reply
#4 Posted : Tuesday, 21 August 2007 12:42:26 AM(UTC)
These power steering pumps are exactly the same as what Ford used, The hex is in the shaft itself not a bolt. If you look deeper into the hole you will see threads (useful to put the pulley back on with using a bolt & some washers).
Now the pulley is
