The thin strip that the HQ kingswood has, and you sometimes see on Monaro, was it STD on Monaro?? the strip i am talking about is approx 1 cm wide, runs along the sill, about 3 inches up from the bottom of the sill. any info appreciated
A1 Bogan. |
These are standard on Monaro (80337/80437) and 71/72 Monaro GTS and GTS 350 (80837/81837), Monaro LS (81137/81237)has wide Premier/Statesman sill trim.
they were deleted from GTS in 73.
Warren
so, that would make them the same part number as the stip on a HQ kingwood ute?
A1 Bogan. |
No a ute and stationwagon are longer.
warren
SEdan shorter? making monaro a 1 off part?
A1 Bogan. |
No Adam, Sedan and coupe have same wheel base so they are the same.
Warren
Hi Guys.
To add to what Warren has said, the Kingswood wagon & Kingswood ute also share their wheelbase dimension (3" longer than sedan/coupe), so they should also share the same (longer) moulding.
Dr Terry. |
The sedan/monaro are the same wheelbase (Statesman/ute/van/wagon are longer, and the tonner longer again). So sill strips for the sedan should be the same as Monaro.
_______________________________________________________ If we all had the same (good) |
Hi Byron.
Isnt that what Warren said.
Dr Terry. |
Hi Byron.
Isn't that what Warren said.
Dr Terry. |
This is wierd. When I placed that post Adam's 13:36pm was the last one there. Now there are two more after it. As you can see I answered the same thing as Warren and I wouldn't have done that if the post was there. It's also been really slow to connect to |
This is wierd. When I placed that post Adams 13:36pm was the last one there. Now there are two more after it. As you can see I answered the same thing as Warren and I wouldnt have done that if the post was there. Its also been really slow to connect to Fa |
so adam, does this means you are going to try and sell standard sedan chrome strips as a "special" monaro 2 door strip????????????
THanks for your interest, ripper. whats it to you??. why dont you use your normal forum name???
Yes, A HQ "snotty" kingswood just came to me with an excellent pair of strips, but its good to know that coupe and "Snotty" ones are the same. I am not o |
THanks for your interest, ripper. whats it to you??. why don't you use your normal forum name???
Yes, A HQ "snotty" kingswood just came to me with an excellent pair of strips, but its good to know that coupe and "Snotty" ones are the same. I am not |
