adam PERTH Offline
#1 Posted : Sunday, 19 August 2007 11:08:28 AM(UTC)
adam PERTH
The thin strip that the HQ kingswood has, and you sometimes see on Monaro, was it STD on Monaro??
the strip i am talking about is approx 1 cm wide, runs along the sill, about 3 inches up from the bottom of the sill.
any info appreciated
A1 Bogan.
#2 Posted : Sunday, 19 August 2007 7:03:59 PM(UTC)
These are standard on Monaro (80337/80437) and 71/72 Monaro GTS and GTS 350 (80837/81837), Monaro LS (81137/81237)has wide Premier/Statesman sill trim.
they were deleted from GTS in 73.
Warren
adam PERTH Offline
#3 Posted : Monday, 20 August 2007 8:34:06 AM(UTC)
adam PERTH
so, that would make them the same part number as the stip on a HQ kingwood ute?
A1 Bogan.
#4 Posted : Monday, 20 August 2007 10:05:48 PM(UTC)
No a ute and stationwagon are longer.
warren
adam PERTH Offline
#5 Posted : Monday, 20 August 2007 10:36:18 PM(UTC)
adam PERTH
SEdan shorter?
making monaro a 1 off part?
A1 Bogan.
#6 Posted : Tuesday, 21 August 2007 5:13:04 AM(UTC)
No Adam, Sedan and coupe have same wheel base so they are the same.
Warren
#7 Posted : Tuesday, 21 August 2007 7:47:16 AM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi Guys.
To add to what Warren has said, the Kingswood wagon & Kingswood ute also share their wheelbase dimension (3" longer than sedan/coupe), so they should also share the same (longer) moulding.
Dr Terry.
#8 Posted : Tuesday, 21 August 2007 10:17:28 PM(UTC)
The sedan/monaro are the same wheelbase (Statesman/ute/van/wagon are longer, and the tonner longer again). So sill strips for the sedan should be the same as Monaro.
If we all had the same (good)
#9 Posted : Tuesday, 21 August 2007 10:26:33 PM(UTC)
Hi Byron.
Isnt that what Warren said.
Dr Terry.
#10 Posted : Tuesday, 21 August 2007 10:26:33 PM(UTC)
Hi Byron.
Isn't that what Warren said.
Dr Terry.
#11 Posted : Wednesday, 22 August 2007 6:22:59 AM(UTC)
This is wierd. When I placed that post Adam's 13:36pm was the last one there. Now there are two more after it. As you can see I answered the same thing as Warren and I wouldn't have done that if the post was there. It's also been really slow to connect to
#12 Posted : Wednesday, 22 August 2007 6:22:59 AM(UTC)
This is wierd. When I placed that post Adams 13:36pm was the last one there. Now there are two more after it. As you can see I answered the same thing as Warren and I wouldnt have done that if the post was there. Its also been really slow to connect to Fa
#13 Posted : Wednesday, 22 August 2007 7:37:34 AM(UTC)
so adam, does this means you are going to try and sell standard sedan chrome strips as a "special" monaro 2 door strip????????????
adam PERTH Offline
#14 Posted : Wednesday, 22 August 2007 10:29:32 AM(UTC)
adam PERTH
THanks for your interest, ripper.
whats it to you??. why dont you use your normal forum name???
Yes, A HQ "snotty" kingswood just came to me with an excellent pair of strips, but its good to know that coupe and "Snotty" ones are the same.
I am not o
adam PERTH Offline
#15 Posted : Wednesday, 22 August 2007 10:29:32 AM(UTC)
adam PERTH
whats it to you??. why don't you use your normal forum name???
I am not
This page was generated in 0.080 seconds.
