basketcasebear Offline
#1 Posted : Sunday, 19 August 2007 11:12:49 PM(UTC)
basketcasebear
hey yall,
I have measured axle widths on transit, and was hoping to see whether I can transplant axle with vn>vp, or which ever one will do it, into transit van, here are measurments>>
drum to drum on transit= 63inchs=1600mm
drum to drum, is virtually end of axle?
wheel arch space, 1460mm tight, allow 25>30mm for clearance= 1500mm
I think i have to make sure whichever axle goes in, i can get strong steel wheels for, alloys wont cut it.
so if anyone knows axle measurements, and has a good idea, will be grateful,
dr tarry,s idea of cutting existing axle is still a possibility, but I do feel a complete changeover will be easier??
considering i want disk brakes, and cant get wider wheels for existing transit?
ptpro
DOH!!!
HK1837 Online
#2 Posted : Monday, 20 August 2007 3:45:52 AM(UTC)
I was going to suggest a H233B diff out of a 1990s Patrol as they are strong as an ox and come in 3.9:1 (Ford Maverick) and disc brakes. But they dont have a handbrake.
So maybe a Dana 44 or 60 out of an F150 or F250 (5 stud) or Jeep Cherokee or J20 (6 s
HK1837 Online
#3 Posted : Monday, 20 August 2007 3:45:52 AM(UTC)
I was going to suggest a H233B diff out of a 1990's Patrol as they are strong as an ox and come in 3.9:1 (Ford Maverick) and disc brakes. But they don't have a handbrake.
#4 Posted : Monday, 20 August 2007 4:16:10 AM(UTC)
basketcasebear
hi byron,
the transits have a five stud pattern, but nothing fits them.!!! and i have found only one ste of nice wheels that fit it, and they were not nice? the only way to get bigger rear wheels is to have them made.
are the widths of the 1,tonner,s an
DOH!!!
#5 Posted : Tuesday, 21 August 2007 1:34:08 AM(UTC)
I could be wrong but I thought that Transit's, F100's, Chev C series/Suburban, some Bedfords and suzuki 4WD's all shared the same comparatively wide stud pattern.
Anyway please read my other reply about the Commodore VN axle being as wide as the Fal
#6 Posted : Tuesday, 21 August 2007 1:34:08 AM(UTC)
I could be wrong but I thought that Transits, F100s, Chev C series/Suburban, some Bedfords and suzuki 4WDs all shared the same comparatively wide stud pattern.
Anyway please read my other reply about the Commodore VN axle being as wide as the Falcon
#7 Posted : Tuesday, 21 August 2007 4:22:39 AM(UTC)
basketcasebear
hey jim.
yep,, found out today, au is 1600mm wide,,, but, no one seems to be able to tell me, which wheels and which backspace,,etc happens on these? and whether avaiable wheels are what rating?? so I am stil trying to find out whether the inner wheel m
DOH!!!
#8 Posted : Wednesday, 22 August 2007 6:11:18 AM(UTC)
basketcasebear
I am getting there,,,
i think i need, an AU falcon one tonner axle, with a 292 ratio diff, and get some steel wheels made, for weight capacity? and for them to sit out from axle, this amount i gotta figure out yet? but it is about 50mm each side? i can
DOH!!!
#9 Posted : Wednesday, 22 August 2007 7:52:11 PM(UTC)
Fallingbear please read my post about relocating cats. Im in the same boat or is that a miniature version of your ocean liner.
Firstly I think that the only factory ratios that you are going to find in an AU/BA/BF are 3.08, 3.27(maybe) & 3.45:1.
#10 Posted : Wednesday, 22 August 2007 7:52:11 PM(UTC)
Fallingbear please read my post about relocating cats. I'm in the same boat or is that a miniature version of your ocean liner.
Firstly I think that the only factory ratio's that you are going to find in an AU/BA/BF are 3.08, 3.27(maybe) & 3.45:1.
#11 Posted : Wednesday, 22 August 2007 10:50:18 PM(UTC)
basketcasebear
jolly good show, jim,
I was told the au diff is a 2.92.?? anyway,s i will ring ford, and if i have too cut wheel archs a tadd,, and find strong wheels fur rating,
ptpro
DOH!!!
#12 Posted : Saturday, 25 August 2007 7:52:25 AM(UTC)
basketcasebear
yep,,
i have finally decided what i am going to do, after all yer help?
I am looking for a AU falcon station wagon axle, [ same as one ton] preferably out of a v8, as this should have a 2.92 diff centre.?
with disks still on it, and tail shaft,
anyo
DOH!!!
#13 Posted : Sunday, 26 August 2007 9:53:52 AM(UTC)
I think that you will not find a 2.92 AU diff as all AUs had an overdrive gearbox so they dont need a high ratio diff.
Having said that you can easily get one fitted with 2.92 gears.
#14 Posted : Sunday, 26 August 2007 9:53:52 AM(UTC)
I think that you will not find a 2.92 AU diff as all AU's had an overdrive gearbox so they don't need a high ratio diff.
#15 Posted : Sunday, 26 August 2007 10:26:44 AM(UTC)
basketcasebear
thanks jim,
I am sure i was told by someone that they have them, cant remember who though?
there is a 58 chev ute over the road, and if I can i might ask if i can measure it, and see what axle is in it? cause it had those really nice wheels, that i thou
DOH!!!
Guest (5)
