klompy Offline
#1 Posted : Monday, 20 August 2007 5:49:08 AM(UTC)
klompy
Hi does any one know how to get the vacum advance unit out of a Bosch electronic dizzy like the ones fitted to the early blue V8s,thanks Mike.
FastEHHolden Offline
#2 Posted : Thursday, 23 August 2007 4:50:59 AM(UTC)
FastEHHolden
Take cap off, remove circlip off vac advance arm, remove screws that hold unit to the body, lift the arm of the breaker plate.
#3 Posted : Thursday, 23 August 2007 5:52:38 AM(UTC)
Hi Guys.
The method set out by FastEHHolden works for Grey & Red motors, but not Blue motors. The Bosch HEI dissy used on Blue motors has the vac advance arm under the reluctor ring, so there is no circlip & no arm to lift up.
The easy way is to ju
klompy Offline
#4 Posted : Sunday, 26 August 2007 4:35:53 AM(UTC)
klompy
Thanks Dr Terry that worked a treat,came of easy but a bit slower to refit but its all good know.What would be a good coil to run with this dizzy.Thanks.
