#1 Posted : Wednesday, 22 August 2007 1:13:40 AM(UTC)
Hello all,
Are there any rules & regulations regarding the placement of catalytic converters?
The problem that I have is with the VN V6 in my Capri the cat is directly fouling a welded in cross member so putting it underneath this cross member would not be good for ground clearance.
I presume moving it forward would be ok but then its beside my transmission (heat issues come to mind) so I would be better off moving it back a foot or so.
Would this be legal?
Regards, Jim..
It shi ts me to tears when the media & state politicians refer to the Federal Government as "Canberra"
basketcasebear Offline
#2 Posted : Wednesday, 22 August 2007 10:44:29 PM(UTC)
basketcasebear
I have no idea jim,
but, i could summize that the cat is there to collect harmful gases, and therefore one could argue, that so long as it is in between the engine, and outside world, it will do what it is designed to do?
might even be betterer, closer,
DOH!!!
#3 Posted : Thursday, 23 August 2007 12:47:06 AM(UTC)
My theory is that if you move it back the gasses going into it will be cooler therefore the cats may be less effective.
Munromad2004 Offline
#4 Posted : Thursday, 23 August 2007 3:59:17 AM(UTC)
Munromad2004
The heat from the exhaust gases is an important part in ensuring the correct function of the catalytic converter. It is actually a chemical reraction taking place inside the converter and the heat plays a major role in this reaction.
As Jim5.0 said abo
arse_wipe Offline
#5 Posted : Thursday, 23 August 2007 6:41:45 PM(UTC)
arse_wipe
Cats are basically an oven and do not work until they are hot (as above),,
Exhaust gasses emmitted until the convertor is operating are EXTREMELY harmful, more so than leaded fuel,,
When unleaded fuels were first used, we were issued with warnings about
John
Silence is non-committal
keithholden Offline
#6 Posted : Thursday, 23 August 2007 9:20:56 PM(UTC)
keithholden
This is the only good thing about NZ people here cut there cats out to get more power. no rules yet, we seem to be 20yrs behind aus in everything but crime rate and jap import cars.
#7 Posted : Thursday, 23 August 2007 10:26:08 PM(UTC)
Mr wipe yes I am in agreeance with you on the oven thing. I think that I'll just place two smaller cats further forward (one either side)and extend the shielding so that it not only protects the floor (which I intended anyway) down so that it also shields
#8 Posted : Thursday, 23 August 2007 10:26:08 PM(UTC)
Mr wipe yes I am in agreeance with you on the oven thing. I think that Ill just place two smaller cats further forward (one either side)and extend the shielding so that it not only protects the floor (which I intended anyway) down so that it also shields
Guest (8)
