Handgunner Offline
#1 Posted : Wednesday, 22 August 2007 7:10:09 AM(UTC)
Handgunner
Hi i have a 202 with tripple sus.....
I want to remove these and run the standard Blue manifold and use a conventional carby and run gas on it...
I have found a manifold, now i just need a carby...
Which one should i use, its going to be in a HT Prem Trimatic Hi Way driver... just concerned with a standard performance type carby..
I have been told the Variax isnt too good?? I am only going to run gas, so can this carby be spudded ? Or do i need to find the gas top air cleaner?
Will this type of carby fit up with the cable linkage ?
Or, do i buy a holley adaptor and run a 350?
I also have been told the xf carby is good.... if so ,is there an adaptor available for the blue carby....looking for the cheap way out :)
Thanks very much...
Bang Bang
Bang Bang
peter_flane Offline
#2 Posted : Wednesday, 22 August 2007 7:50:16 AM(UTC)
peter_flane
When on gas, the carby becomes a throttle body. The fuel is dispensed by the mixer. I ran a 202 with a Holley 350, and it was a good throttlebody. I also had a 253 with a flogged out Rochester that was great as a gas throttlebody, but needed a full reco t
adam PERTH Offline
#3 Posted : Wednesday, 22 August 2007 10:12:41 PM(UTC)
adam PERTH
I think the Varijet would be a better option on gas than a 350 Holley.
Remember, simular internals to Q-Jet, tune accordingly.
also bigger CFM
Varijet 1 - 375 CFM
Varijet 11 - 398 CFM.
A1 Bogan.
#4 Posted : Thursday, 23 August 2007 3:09:36 AM(UTC)
my 253 runs gas, I have a 2 barrel stromberg pre immision carby and it runs well, the guy who rebuilt it said they were good for gas as they are a simple design.
FastEHHolden Offline
#5 Posted : Thursday, 23 August 2007 3:10:35 AM(UTC)
FastEHHolden
If you are on gas only..impco 225...or if you engine has a bit of work..and impco 425.
adam PERTH Offline
#6 Posted : Thursday, 23 August 2007 5:12:10 AM(UTC)
adam PERTH
Would it be a fair comment to say the best performance Gas technology comes out of Victoria????
A1 Bogan.
peter_flane Offline
#7 Posted : Thursday, 23 August 2007 5:20:01 AM(UTC)
peter_flane
adam PERTH Offline
#8 Posted : Thursday, 23 August 2007 5:23:25 AM(UTC)
adam PERTH
Not an opinion really, more a retorical question.
A1 Bogan.
#9 Posted : Thursday, 23 August 2007 8:56:09 AM(UTC)
Well down in Vic there are so many cars running LPG that you would be hard pressed to find a service station that dost sell auto LPG so yes most LPG gear comes from VIC. I was a bit dismayed when I moved back to Canbera from Albury & found that not all se
#10 Posted : Thursday, 23 August 2007 8:56:09 AM(UTC)
Well down in Vic there are so many cars running LPG that you would be hard pressed to find a service station that dos't sell auto LPG so yes most LPG gear comes from VIC. I was a bit dismayed when I moved back to Canbera from Albury & found that not all s
vintageholden Offline
#11 Posted : Thursday, 23 August 2007 11:39:57 AM(UTC)
vintageholden
i,m running impco 300A
or will be soon
after 2brl or 4 brl manifold fo holden 6
#12 Posted : Thursday, 23 August 2007 4:14:27 PM(UTC)
At Cessnock swap last week that was one thing I saw a lot of ie 2 and 4 barrel Holley manifolds for Holden sixes.
#13 Posted : Friday, 24 August 2007 6:10:03 AM(UTC)
Jim is spot on... a vk efi manifold is by far the best manifold for straigt gas(without spending heaps of cash) and then you just bolt a gas research carby straight on to original throttlebody location. Gas convertor then bolts neatly on to the existing
Handgunner Offline
#14 Posted : Saturday, 25 August 2007 7:57:28 AM(UTC)
Handgunner
Well, here is what i got :)....
Went to local wreckers, got a vk/vh Fuel injection manifold with throttle bady, got a gas ring from a fairlane EFI and a few linkages and a rubber tube thingy to mount a pod on...if needed.....
Now i am gonna just mount
Bang Bang
#15 Posted : Sunday, 16 September 2007 6:12:18 AM(UTC)
Hey fellas,
Does anyone know any manufacturers who make 3.3 blue manifolds to suit tripple SU carbs "HS6 Type". I've tried redline, but to no avail.
#16 Posted : Sunday, 16 September 2007 6:12:18 AM(UTC)
Hey fellas,
Does anyone know any manufacturers who make 3.3 blue manifolds to suit tripple SU carbs "HS6 Type". Ive tried redline, but to no avail.
#17 Posted : Tuesday, 18 September 2007 4:11:11 PM(UTC)
Jim
I dont think you can buy a triple carb manifold for a blue motor. In fact there are bugger all manifolds to suit. In reality though, youll not gain all that much by using a blue head with triple SUs or Strombergs, so you might find it easier to use
#18 Posted : Tuesday, 18 September 2007 4:11:11 PM(UTC)
Jim
I don't think you can buy a triple carb manifold for a blue motor. In fact there are bugger all manifolds to suit. In reality though, you'll not gain all that much by using a blue head with triple SU's or Strombergs, so you might find it easier to
#19 Posted : Wednesday, 19 September 2007 6:46:00 AM(UTC)
vintageholden
i have impco 300A gas carby if anyone interested
make an offer
This page was generated in 0.093 seconds.
