HoldensRule Offline
#1 Posted : Tuesday, 28 August 2007 11:19:44 AM(UTC)
HoldensRule
Im all new to this but can someone tell me what they mean on the 308 V8 what the "TURBO" pattern means?
#2 Posted : Tuesday, 28 August 2007 4:59:59 PM(UTC)
Hi HoldensRule.
There are 2 different gearbox bolt patterns on the back of early 308 V8 blocks.
The automatic transmission used from 1974 to 1982 was either the Turbo-Hydramatic 400 or Turbo-Hydramatic 350. These autos used a differently patterned b
HoldensRule Offline
#3 Posted : Tuesday, 28 August 2007 7:03:04 PM(UTC)
HoldensRule
so to bolt a manual to a turbo pattern motor you would need a manual gearbox flywheel to suit
#4 Posted : Tuesday, 28 August 2007 7:21:30 PM(UTC)
Hi HoldensRule.
No. it's the pattern on the block itself. You will, of course, need a manual flywheel, but this will bolt straight onto the crank.
If you want to fit a manual box, you will need a different bellhousing to suit the block.
If it's a
#5 Posted : Tuesday, 28 August 2007 7:21:30 PM(UTC)
Hi HoldensRule.
No. its the pattern on the block itself. You will, of course, need a manual flywheel, but this will bolt straight onto the crank.
If its a S
HoldensRule Offline
#6 Posted : Tuesday, 28 August 2007 7:38:57 PM(UTC)
HoldensRule
Thanks Dr
