#1 Posted : Wednesday, 29 August 2007 12:50:55 AM(UTC)
iam rebuilding a 202 and i would like to give it a hone before i fit the new rings can anyone tell me how tom go about it
iam rebuilding a 202 and i would like to give it a hone before i fit the new rings and pistons i would like to give it a go myself i like to learn anyone got any tips? cheers
keithholden Offline
#2 Posted : Wednesday, 29 August 2007 2:45:35 AM(UTC)
keithholden
Hi Buy a hone that goes on the drill. Check the top of the bore as there maybe a lip and if you put new rings on these could hit the lip. I borrowed a lip remover from a nice engine reconditioner back when I did mine. The lip is caused by wear in the bore
adam PERTH Offline
#3 Posted : Wednesday, 29 August 2007 4:16:37 AM(UTC)
adam PERTH
Buy some "file to fit" rings to get a better gap if you are just re-ringing.
The location of the rings in relation to each other, the leading edge and gap are all important factors.
Get the block ridge-reamed like kieth said to get rid of lip, or you
#4 Posted : Wednesday, 29 August 2007 9:02:27 AM(UTC)
use kerosine for honing, run the hone up and down as it rotates so that you see a cross hatch pattern in the bore. stop the drill before removing the hone if it is one of the hones with a grinder stone in it, if the drill is still rotating you risk breaki
